Loading...
Pages: [1]   Go Down
Author Topic: Problems with l293ne  (Read 276 times)
Offline Offline
Newbie
View Profile
Hi everybody, I amdeveloping the l293ne ic to control a simple motor. What I have made so far is to join with solder the ic on a stripboard as you can see in the picture. Before join the stripboard I checked it and it worked, but now it doesnt. Can anyone check my connections in order to see if I have something wrong.
Thank you very much in advance and sorry for any inconvenience.
Enrique
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
How about a photo of the underside of the stripboard, so we can see which tracks you cut?
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Newbie
View Profile
Sorry, I did not notice that the connections could not being tracked ;-)
Thank you!
Logged
United Kingdom
Offline Offline
Faraday Member
View Profile
WWW
Your circuit doesn't include the output diodes. The L293D variant has these built in, the L293NE does not. Running the chip with a motor or other inductive load but no diodes is likely to damage the chip.
Also, you should connect all 4 ground pins together, however this is probably not too important.
Logged
Offline Offline
Newbie
View Profile
Thank you for your reply, I tested it a while ago and it was the grounds what was wrong. Anyway, I dindnt know about the diodes, so I will change the schematics.
Thank you again
Logged
Pages: [1]   Go Up
Print
Jump to:
