Topic: Tutorial of Xbee Based Arduino Mega UHF RFID Reader up to 5 meters distance (Read 13998 times) previous topic - next topic
Jingfeng
In this tutorial, we are going to demo two parts:
1. Using the UHF demo GUI, and host PC GUI actively scans the tag over Xbee. This will demonstrate the RSSI and tag information. Arduino mega acts as a serial bridge between the UHF RFID reader and the Xbee.
2. Using the Arduino mega to issue scan tag command, and report the number of found tags on the LCD. Debug information is sent wirelessly to the serial terminal using Xbee.
Hardware:
Arduino Mega
Xbee
Xbee 3.3V to 5V breakout board
Xbee USB Adapter
TTL UART UHF RFID Reader
RFID Reader Antenna
3V/2A DC Wall Adapter
2X16 LCD
Pin 1 of Xbee (VCC) is connected to Arduino Mega's 5V.
Pin 2 of Xbee (DOUT) is connected to Arduino Mega's digital 1, TX.
Pin 3 of Xbee (DIN) is connected to Arduino Mega's digital 0, RX.
Pin 10 of Xbee (GND) is connected to Arduino Mega's ground.
Ground of RFID module is connected to Arduino mega's gound.
RX of RFID module is connected to Arduin mega's digital 18, TX1.
TX of RFID module is connected to Arduin mega's digital 19, RX1.
For the 16X 2 LCD:
pin 1 of LCD -> Ground
pin 2 of LCD -> +5V
pin 3 of LCD-> the center leg of a 10K potentimeter, where the other two legs are connected to 5V and ground.
pin 4 of LCD -> digital pin 12 of arduino mega
pin 5 of LCD -> Ground
pin 6 of LCD -> digital pin 11 of arduino mega
pin 11 of LCD -> digital pin 5 of arduino mega
pin 12 of LCD -> digital pin 4 of arduino mega
pin 13 of LCD -> digital pin 3 of arduino mega
pin 14 of LCD -> digital pin 2 of arduino mega
The Xbee module on the PC side, which sits on the Xbee USB adapter, needs to be configureed to 115200.
The other xbee, which sits on on the Xbee 3.3V to 5V on the arduino mega sides, needs to be configured to 9600.
Part 1: Scan tags using PC GUI over Xbee
The PC GUI can be downloaded from: http://www.linksprite.com/download/showdownload.php?id=118&lang=en.
The sample Arduino code can be downloaded from: http://www.linksprite.com/download/showdownload.php?lang=en&id=122
Launch the GUI, and add a serial reader.
Click the scan button:
Note: if it doesn't work, you can use serial terminal to monitor the PC sides's Xbee output, sometimes, if the power supply can't provide enough current, the RFID module will reset. This can be confirmed by checking to see if "hello" message pop up when you did a scan. If it does, that means the module restart due to low current from the wall adapter.
Part 1: Scan tags using Arduino mega
The sample Arduino code can be downloaded from:http://www.linksprite.com/download/showdownload.php?lang=en&id=123
Now, in X-CTU, by pressing 'r', the LCD will display the number of tags found.
Note: the number of tags can vary. Multiple scans are needs to allow the collision avoidance.
mdelgiudice
I am interested in your project.
UHF reader which you used?
Do you think you can replace the card xbee with a Wi-Fi card
Shield - WiFi Code: A000058
Thanks
LouP
For the UHF reader, I would suggest using super-easy reader chip like Impinj RS500 (just connect power, antenna, UART and you have a UHF reader):
http://www.impinj.com/Indy_RS500_RFID_Reader_SiP_Solution.aspx
johnfoneill
Could I ask what antenna you used to connect to the RS500?  I'm looking a small inexpensive one.
Thanks,
John
aimank_
Hi, i am interested to know more about your project since im doing something similar for my final year project in school. May i know if it's possible for me to use arduino uno instead of mega?
