Topic: Cannot Find WProgram.h (differant) (Read 18824 times) previous topic - next topic
partyk1d24
Ok so here is the deal,
Environment:
Compiled from Git Repo
Ubuntu x64
Last night I was successful at doing the blinking light tutorial using the sketch window. Now I want to create a C Library to do the Morse example. I am trying to do this in C instead of C++ but which I don't think should be that tough, but I am no expert. So I create the following in ./libraries/Morse
Code: [Select]
  Morse.h - Library for flashing Morse code.
  Created by David A. Mellis, November 2, 2007.
  Released into the public domain.
#ifndef Morse_h
#define Morse_h
#include <WProgram.h>
class Morse
  public:
    Morse(int pin);
    void dot();
    void dash();
  private:
    int _pin;
#endif
Morse.H
Code: [Select]
#include "WProgram.h"
#include "Morse.h"
Morse::Morse(int pin)
  pinMode(pin, OUTPUT);
  _pin = pin;
void Morse::dot()
  digitalWrite(_pin, HIGH);
  delay(250);
  digitalWrite(_pin, LOW);
  delay(250);
void Morse::dash()
  delay(250);
Morse.c
Now comes the tricky part, first if I try to do what I want (which is compile using gcc Morse) I get the following...
Code: [Select]
jackie@jackie-Latitude-E6410:~/Development/Code/Arduino/libraries/Morse$ gcc Morse.c
Morse.c:1:22: fatal error: WProgram.h: No such file or directory
compilation terminated.
And if I use the sketch window I get the following...
Code: [Select]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec]
     [exec] In file included from /home/jackie/Development/Code/Arduino/build/linux/work/libraries/Morse/Morse.c:2:
     [exec] /home/jackie/Development/Code/Arduino/build/linux/work/libraries/Morse/Morse.h:6: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'Morse'
     [exec] /home/jackie/Development/Code/Arduino/build/linux/work/libraries/Morse/Morse.c:4: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
     [exec] /home/jackie/Development/Code/Arduino/build/linux/work/libraries/Morse/Morse.c:10: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
     [exec] /home/jackie/Development/Code/Arduino/build/linux/work/libraries/Morse/Morse.c:18: error: expected '=', ',', ';', 'asm' or '__attribute__' before ':' token
Any ideas?
Thanks!
baum
In morse.c, change "wprogram" to <wprogram>
http://stackoverflow.com/questions/21593/what-is-the-difference-between-include-filename-and-include-filename
partyk1d24
Changed to...
Code: [Select]
#include "Morse.h"
Also tried
Code: [Select]
#include <Morse.h>
Response
Code: [Select]
Code: [Select]
jackie@jackie-Latitude-E6410:~/Development/Code/Arduino/libraries/Morse$ ls
Morse.c  Morse.h
I will go over the link in a bit, any other ideas in the meantime?
baum
What happens if you don't include it?
SurferTim
#4
Aug 25, 2011, 12:12 pm Last Edit: Aug 25, 2011, 01:28 pm by SurferTim Reason: 1
The WProgram.h should be added by the Arduino package by default. Mine does.
It is in the Arduino includes if you need it outside the Arduino package.
/arduino/cores/arduino/WProgram.h
Try adding a return type for the Morse function. Like this:
Code: [Select]
void Morse::Morse(int pin)
 _pin = pin;
Change it in the Morse.h file also.
Code: [Select]
class Morse
 public:
   void Morse(int pin);
   void dot();
   void dash();
ADD: To stay with the norms of the Arduino/Atmel code, I would have called that function
Code: [Select]
void Morse::begin(int pin)
I see who wrote that Morse program. Isn't this the guy that maintains the Arduino IDE?
I like to know what weaknesses a programmer has if I am about to troubleshoot other code by the same programmer.
BTW, mine is mismatched curly braces. If I post code here, that is the first thing you should check.
That is why I may seem so anal about the curly brace alignment and indentation on my code.
partyk1d24
Thanks I will try this... remember when it come to "should be included" that I am compiling this from source and not using apt-get or something similar. Again I am a little new to C do you know how to include a header file from another directory?
partyk1d24
P.S. I don't see that header. Do I need to compile something differantly?
Code: [Select]
jackie@jackie-Latitude-E6410:~/Development/Code/Arduino/core$ ls
api.txt  build.xml  done.txt     make.sh  preproc     src
bin      core.jar   license.txt  methods  preproc.pl  todo.txt
Jackie
SurferTim
#7
Aug 26, 2011, 11:35 am Last Edit: Aug 26, 2011, 11:55 am by SurferTim Reason: 1
That directory listing appears to be the build directory. If you want to know if it is working, try this short code. If the noTone function does not generate a compiler error, the WProgram.h file has been included.
Code: [Select]
 noTone(13);
These both include a header file. The first includes the WProgram.h file from the default include directory. The second includes the file from the current directory.
Code: [Select]
I do not need either of those to compile that code in the Arduino IDE.
partyk1d24
So after I execute ant on the build directory, where does it get built to? Do I have to have the header file in my classpath like Java? Where would the header file be after I built the project?
partyk1d24
Finally found the WProgram.h file it is in...
./hardware/arduino/cores/arduino
Anyone have any helpful tips on how to include or install it?
partyk1d24
Tried this... no dice still...
Code: [Select]
jackie@jackie-Latitude-E6410:~/Development/Code/Arduino/libraries/Morse$ gcc -I ../../hardware/arduino/cores/arduino/ -c ./Morse.c
In file included from ./Morse.c:1:0:
../../hardware/arduino/cores/arduino/WProgram.h:8:27: fatal error: avr/interrupt.h: No such file or directory
SurferTim
#11
Aug 29, 2011, 04:08 pm Last Edit: Aug 29, 2011, 04:27 pm by SurferTim Reason: 1
My apology for not getting back to you sooner. It was imperative I get my version of the Arduino compiler working.
You should be able to put it in the same directory as your code.
Then use
EDIT: I see you have other challenges with the includes in the WProgram.h file.
I suggest remove the
#include "Wprogram.h"
statement from the code. That code shouldn't need it. There is nothing but setting pins and delay().
I took a look at the WProgram.h file. It appears to be a function set for producing an audible tone if you had an audio amp connected. Not required if you are just flashing the pin 13 LED.
partyk1d24
Thanks I will try out removing it (and no worries about response time we are all busy)...
Quote
Then use
When you say "it" do you mean I can just copy the WProgram.h header file into the same directory? I am new to C so is the header file just an interface description and has no need for a class or object file?
Thanks
Jackie
anon10500
http://code.google.com/p/arduino/wiki/Arduino1
Quote
Renamed WProgram.h to Arduino.h.
shadababe04
RENAME WProgram.h to Arduino.h in the cpp file of library
