Topic: Starting sketch before connection to pc (Read 943 times) previous topic - next topic
mskinder
I'm trying to make an arduino uno output times to serial, sort of a external stopwatch,
and I have managed to do this. But I was wondering if it is possible to start the sketch,
and the timing, before I connect the arduino to the pc, so that I can start in one place,
and then move to the "finish line", without having to move the computer also.
Is it possible, and if yes, how?
Thanks
Grumpy_Mike
You need two things.
1) To power the arduino. This can be done by batteries and will start a sketch running.
2) To disable the auto reset that resets the arduino when ever the serial port is enabled. There is a link on the board you can cut to do this.
mskinder
Where can I find the link I would need to cut?
Thank you very much for the reply   :D
Grumpy_Mike
Depends on what you have. This link shows you haw for some versions:-
http://www.arduino.cc/playground/Main/DisablingAutoResetOnSerialConnection
On the uno it is a pad to the left of the resistor pack marked reset close to pin 14 of the ATmega chip, slice the thin wire in between and add a solder blob to reconnect.
mskinder
Thank you so much for all your help!  :)
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
