Chateauguay
Offline
Full Member
-8 years old: LEGO BLOKS 8 to 9 years old: little cards magician 9 to 12 years old : meccano 13 years old: Arduino Uno!!!! Usually my real dream was to make little gadjets and that sort of stuff =)
« on: August 25, 2011, 03:19:07 am » |
is there any easy and simple way to change a polarity/ side/ direction or a +/- of a dc motor.
Logged
Global Moderator
UK
Offline
Brattain Member
I don't think you connected the grounds, Dave.
« Reply #1 on: August 25, 2011, 05:26:54 am » |
DPDT relay?
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Bristol, UK
Offline
Edison Member
Exhibitor at UK Maker Faire
« Reply #2 on: August 25, 2011, 08:33:29 am » |
Maybe an H-bridge?
Logged
Calgary, AB
Offline
Newbie
Arduino Newbie
« Reply #3 on: August 25, 2011, 10:27:01 am » |
Hi Muneeb Simplest solution DPDT switch (double pole double throw) If you used center off, then you would also get an off position. The motor gets wired to the center position. E.g. http://www.robotroom.com/DPDT-Bidirectional-Motor-Switch.htmlRegards Bill
Logged
Don't you just hate ONE D 10 T problems?
Chateauguay
Offline
Full Member
« Reply #4 on: August 26, 2011, 01:36:11 pm » |
there are no programming code to change a polarity?
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #5 on: August 26, 2011, 01:38:26 pm » |
Yes, of course, unless you're using physical switches
Logged
Chateauguay
Offline
Full Member
« Reply #6 on: August 26, 2011, 02:05:13 pm » |
Any video or tutorial for this,
is it also possible to change a +/- of a dc motor using a potentionmeter or a photo resistor with a code
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #7 on: August 26, 2011, 02:10:28 pm » |
Tell us what hardware you've got and what sort of a motor you're trying to control.
(and please, don't just say "it's a 12V motor")
Logged
Chateauguay
Offline
Full Member
« Reply #8 on: August 26, 2011, 07:14:20 pm » |
i have an arduino uno, and im trying to controlle a +/- of dc motor that is 3 to 9 volts
Logged
Offline
Newbie
« Reply #9 on: August 26, 2011, 08:55:33 pm » |
There are some motor controller shields for the arduino. Easiest way. Plenty of code examples.
Logged
Chateauguay
Offline
Full Member
« Reply #10 on: August 26, 2011, 10:31:51 pm » |
so tell me the code
Logged
Offline
Newbie
« Reply #12 on: August 27, 2011, 12:26:35 am » |
Logged
Global Moderator
UK
Offline
Brattain Member
« Reply #13 on: August 27, 2011, 03:34:01 am » |
im trying to controlle a +/- of dc motor that is 3 to 9 volts I suppose I asked for that.  When asked to describe a motor, you need to state the voltage and the current. Think about it; a slot-car runs on 12V, but so does a starter motor.
Logged
