Topic: Synthetiserphone finished !!! (Read 2522 times) previous topic - next topic
ikaruga
I just finished building my own synthetiser  ! My first electronic device ever. Was so fun !! It s crazy how many hours i spent making holes and cutting wires, I m not a very craftish person, I like digital stuff more. But this electronic sculpture was a blast to build ! I ve never done any sort of electronics before this, so it was a lot of learning : )
I ve made a sound demo: http://vimeo.com/295157
and here s some pics on Flickr : http://www.flickr.com/photos/12335826@N00/1306528722/in/photostream/
Daniel
that is way cool, can we see the code and schematic?
D
ikaruga
// TONES  ==========================================
//       note, period, &  frequency.
#define  R     0
#define  c     3830    // 261 Hz
#define  d     3400    // 294 Hz
#define  e     3038    // 329 Hz
#define  f     2864    // 349 Hz
#define  g     2550    // 392 Hz
#define  a     2272    // 440 Hz
#define  b     2028    // 493 Hz
#define  C     1912    // 523 Hz
#define  SN   10000    // SNARE
#define  KI   13000    // SNARE
// SETUP ============================================
int videoOut = 8;
int speakerOut = 9;
int subOut = 10;
int ledPin = 12;
int potPin = 2;
int tempoOut = 0;
int inPin = 7;   // choose the input pin (for a pushbutton)
int val = 0;     // variable for reading the pin status
// Do we want debugging on serial out? 1 for yes, 0 for no
int DEBUG = 1;
 pinMode(speakerOut, OUTPUT);
 pinMode(subOut, OUTPUT);
 pinMode(videoOut, OUTPUT);
 pinMode(ledPin, OUTPUT);      // sets the digital pin as output
 pinMode(inPin, INPUT);    // declare pushbutton as input
 if (DEBUG) {
   Serial.begin(9600); // Set serial out if we want debugging
// MELODY and TIMING  =======================================
int melody[] = { KI};
int beats[]  = { 16};
int MAX_COUNT = sizeof(melody) / 2; // Melody length, for looping.
// CONFIG             =======================================
long tempo = 60000;
int pause = 5000;
int rest_count = 0; //<-BLETCHEROUS HACK; See NOTES
int tone = 0;
int beat = 0;
long duration  = 10;
// PLAY TONE  ==============================================
void playTone() {
 long elapsed_time = 0;
 if (tone > 0) {
   while (elapsed_time < duration) {
val = digitalRead(inPin);  // read input value
     digitalWrite(speakerOut,HIGH);
     if (val == HIGH) {     digitalWrite(subOut,HIGH); } else { };
     digitalWrite(videoOut,HIGH);
     digitalWrite(ledPin, HIGH);   // sets the LED on
     delayMicroseconds(tone / 2);
     digitalWrite(speakerOut, LOW);
     if (val == HIGH) {     digitalWrite(subOut,LOW); } else { };
     digitalWrite(videoOut, LOW);
     digitalWrite(ledPin, LOW);    // sets the LED off
     // Keep track of how long we pulsed
     elapsed_time += (tone);
 else { // Rest beat; loop times delay
   for (int j = 0; j < rest_count; j++) { // See NOTE on rest_count
     delayMicroseconds(duration);
// LET THE WILD RUMPUS BEGIN =============================
 int potone = analogRead(potPin);    // read the value from the sensor
 // Set up a counter to pull from melody[] and beats[]
 for (int i=0; i<MAX_COUNT; i++) {
   tone = potone*10 ;
   beat = beats[i];
   playTone();
   // A pause between notes...
   delayMicroseconds(potone*1000);
   if (DEBUG) { // If debugging, report loop, tone, beat, and duration
     Serial.print(i);
     Serial.print(":");
     Serial.print(beat);
     Serial.print(" ");
     Serial.print(tone);
     Serial.print(" ");
     Serial.println(duration);
Voila!
I m glad you liek ^_^
For the schematics well .. I ll make them tonight , they re gonna be a asshole to draw, there s 7-8 output pins and a couple more : p
Narbotic
Aah, so that's why you've been so quiet.
Ecellent work!
ikaruga
yay thanks narbotic : ) !!! no need to say you ve been my inspiration on this : ) Sorry bout the quietness ^_^ UPDATE YOUR BLOG !
