Topic: changing a polarity or a +/- of a dc motor? (Read 3876 times) previous topic - next topic
Muneeb
is there any easy and simple way to change a polarity/ side/ direction or a +/- of a dc motor.
AWOL
Anachrocomputer
Bill_Kerr
Hi Muneeb
Simplest solution DPDT switch (double pole double throw)
If you used center off, then you would also get an off position.  The motor gets wired to the center position.
E.g.  http://www.robotroom.com/DPDT-Bidirectional-Motor-Switch.html
Regards  Bill
Don't you just hate ONE D 10 T problems?
Muneeb
there are no programming code to change a polarity?
AWOL
Yes, of course, unless you're using physical switches
Muneeb
Any video or tutorial for this,
is it also possible to change a +/- of a dc motor using a potentionmeter or a photo resistor with a code
AWOL
Tell us what hardware you've got and what sort of a motor you're trying to control.
(and please, don't just say "it's a 12V motor")
Muneeb
i have an arduino uno,
and im trying to controlle a +/- of dc motor that is 3 to 9 volts
ilektron
There are some motor controller shields for the arduino.  Easiest way.  Plenty of code examples.
http://ilektron-x.blogspot.com - Hacking and General Electronics Goodness
Muneeb
ilektron
Here is my blog with a higher current motor shield.  I thought I had some example code on there, let me find it.
http://ilektron-x.blogspot.com/search/label/high%20current%20motor%20controller%20shield
ilektron
This is just a rudimentary example to control the motor shield.
http://ilektron-x.blogspot.com/2011/02/high-current-motor-controller-shield.html
AWOL
I suppose I asked for that. :smiley-roll-blue:
When asked to describe a motor, you need to state the voltage and the current.
Think about it; a slot-car runs on 12V, but so does a starter motor.
