Loading...
Pages: [1]   Go Down
Author Topic: My First Arduino  (Read 400 times)
Canada
Offline Offline
Newbie
Arduino & Freeduino rocks!
View Profile
WWW
Actually, it's a Freeduino based off the Arduino, but it's essentially the same and it works with the Arduino drivers and dev program.  Now that I got that over with...
Anyways, I have finished my first program.  It's the flash sketch, but I made some very simple modifications; it will only flash 5 times, and it uses Serial to print to the computer that it has flashed 5 times.  The LED I used is a flashing LED, so it flashes for a second instead of staying solid.  I have a good knowledge of Java and C programming, and I thought I should give this a try to learn more things about the electronics side.
Check it out; I hope to do more stuff whenever I get the time.
Code:
#define ledPin 13  // LED connected to digital pin 13
#define FLASHES 5  // How many times the LED will flash
  Serial.begin(9600);           // Sets the baud rate to send serial data to my computer
  pinMode(ledPin, OUTPUT);      // sets the digital pin as output
  int i;
  for (i = 0; i < FLASHES; i++)
    digitalWrite(ledPin, HIGH);   // sets the LED on
    delay(1000);                  // waits for a second
    digitalWrite(ledPin, LOW);    // sets the LED off
    Serial.println(i+1,DEC);      // print the amount of times it has flashed so far
  //Print a sentence stating how many times it has flashed
  Serial.print("I am done flashing ");
  Serial.print(FLASHES,DEC);
  Serial.print(" times.");
  I'm not using the loop function below because I only want the program to run the code once :(
void loop(){}
Edit:  After posting this, I later found a red LED and it worked like it should smiley-grin
« Last Edit: November 20, 2007, 09:51:37 pm by Anthony » Logged
Buy a breadboard; it's worth it!
Pages: [1]   Go Up
Print
Jump to:
