After a lot of trying a have manage to made a successful config of one of the xbee's. But the other one is giving me some kind of error.
Here are a picture of the xbee's, the one on the USB explorer are giving the error. The other is now config without problem. http://dl.dropbox.com/u/1777161/foto-1.JPG
I did the following with success on one of them and error on the other.
First Xbee's:
My input Respons
+++ ok
ATMY1000 (enter) ok
ATDL1001 (enter) ok
ATID1111, (enter) ok
WR (enter)
Then I checked:
ATMY (enter) 1000
ATDL (enter) 1001
ATID (enter) 1111
Then the second xbee:
+++ ok
ATMY1001 (enter) Error
ATDL1000 (enter) ok
WR (enter)
Then I checked:
ATMY (enter) FFFE
ATDL (enter) 1000
ATID (enter) 1111
Unless I'm misreading them you have two incompatible XBees. One of them is a series 1 and the other is a series 2; these can't talk to each other. Series 2 need another series 2 to work and the same with Series 1. Flip the modules over and look at the label on the RF shield, it should have a part number on it. Then go to the Digi site and look them up to be sure.
This is also supported by the fact that the MY command doesn't work on one of them. On Series 1, MY is used to set an address; on Series 2, MY is used to read the address the device is assigned by the coordinator device.
And it says it can be used with the xbee shield.
Do I have to config it as well?
Course if I plug it in or if I plug it in the spark fun usb explorer I can't see it on my computers Bluetooth?
There is a link on that page to a pdf file that contains a link to a Seeedstudio forum with details on how to set up the device. Have you followed those links?
