Topic: Component in Eagle (Read 3118 times) previous topic - next topic
LuisSoares
I´m sure this or a similar component is present in Eagle PCB libraries, but i can´t find it.
It´s a DIP screw terminal.
Component:
http://uk.farnell.com/multicomp/pa001-6/terminal-block-pcb-6way-vertical/dp/1357321
Can someone help me?
Best regards
James C4S
I searched the library for "screw".  Under con-wago-500 there are a series of screw clamps which may be similar to the part you are asking about.  It might take a little bit of research to verify.
You could also just use a "header" with the same spacing, then draw a box around it as a visual keep out.
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
MarkT
The Wago 500's are 0.2 inch spacing, which is a common pitch for screw terminals, the Multicomp one you link to is actually 5.00mm spacing, which will match for a short row, but a long strip will misregister as 0.2" is 5.08mm.  Buy sets of 2 3 or 4 and they will likely fit, more than that and they probably won't...
Its relatively easy to define your own components in Eagle BTW.
Also Farnell probably have some 0.2" spacing connectors too...
CrossRoads
Look for Phoenix - the library has parts for them.
Boz
Sort of a threadjack, does anyone know if there a 2.54 pitch version of this type of screw terminal, that would fit perfboard.
CrossRoads
Did you search for Phoenix at all?
http://search.digikey.com/scripts/DkSearch/dksus.dll
James C4S
As Crossroads suggests, look to Phoenix.  I looked on Mouser and found 5.08 pitch headers from Phoenix.
CrossRoads
Here's their 2-pin version.
Didn't realize I hadn't grabbed the Phoenix parts in the search.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=277-1273-ND
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
