Topic: ArduIMU: First Arduino IMU test (ArduCopter) (Read 3031 times) previous topic - next topic
jordi
Jan 15, 2008, 05:30 pm Last Edit: Jan 15, 2008, 05:33 pm by jordi Reason: 1
Hello, i found a good family here in http://www.diydrones.com/, is an excellent group of people trying to build an automatic airplane like me, they are helping me with the Arduino automatic pilot and the translation stuff.  ::)
Info and source code here:
http://www.diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A19829
Don't forget read the comments, i explained a litte bit more about Kalman Filters.
Jordi   ;)
eustace
That's really impressive code, Jordi.  Since you are putting this into a heli, are you planning to make a single PCB to hold down weight?  Perhaps a socketed ATmega168 and your sensors, nothing else?
jordi
Yes maybe, or perhaps a simple PCB with mini arduino slots on it.  ;D I possible to use the same crystal for two atmegas168?
kg4wsv
Quote
Crystal? I don't think so.
A TTL crystal oscillator, however, is a different story.  With careful board layout you may be able to drive multiple inputs with an oscillator.
That will probably require fuse changes, though.
-j
jordi
Yes the crystal oscillator (16mhz), CAN I USE one crystal for two atmegas 168???  :-/
jordi
#5
Feb 01, 2008, 05:48 am Last Edit: Feb 01, 2008, 06:00 am by jordi Reason: 1
OK here is the final version of the ArduIMU.
Video:
http://youtube.com/watch?v=1DDEH2n2_hY
-Yellow color = Just Accelerometer read
-Red color= Accelerometer+Gyro+KalmanFIiter
Arduino Source Code:
http://jordii07.googlepages.com/ArduIMUFinal.txt
Labview (ground station) source code:
http://jordii07.googlepages.com/IMUfinal.llb
I configured Arduino to externally adjust the accelerometer jitter filter and the gyro rate, using the nunchuck potentiometers (joystick axis). Now is working pretty well.
To do:
-Integrate another Gyro (to make it dual axis).
-A bank robbery, to buy all the components i need.
-Program the SPI altimeter
-And put all the hardware together and make it work (gps, altimeter, IMU, modem).
-Making a PSP program to read serial data (using psp uart port).  ::) to make a portable ground station. (but this is a secret)
