Loading...
Pages: [1]   Go Down
Author Topic: PCB export to gerber question.  (Read 462 times)
West palm beach, FL
Offline Offline
Sr. Member
View Profile
Im not sure if this is out of bounds as far as general electronics goes, but my question is as follows,
 i am using sprint-layout to design a circuit which will later be produced on a pcb, however when exporting the design to gerber file it gives options to mirror a layer, as a matter a fact it pre selects mirror for the top lay of copper which makes me think that is how it SHOULD be , should i mirror it? because when i do  then obviously everything is wayyy off, as far as i understand when i am designing a board on most if not all layout designers , it is as if you are looking at the board from the top side and the board is transparent so you can see the bottom copper traces....am i right? if this is the case then mirroring any layers would be a bad move... if so why would they even put it as an option. just to mess with my head ? or maybe i am wrong.... any insight? when opening the gerber files with any gerber viewer they are all wrong because of the mirroring..which further leads me to belive no mirroring... correcto mundo?
Logged
I could print the Arduino logo on a box of cereal and sell it as "Arduin-O's"
Scotland
Offline Offline
God Member
Have you had your Arduino fix today?
View Profile
WWW
Generally NO, Do not mirror any layer - as you have already seen, it puts everything out of sync.
Export all layers as seen from the front of your board, But if you do make a mistake, most good fab houses will
notice and get back to you.
P.S. Most Batch services Don't check anything, so be carefull with them.
Logged
Drew.
(MyPCB MANUFACTURING SERVICE)
Duemilanove - UNO - Leonardo - Mega 1280 - Mega 2560 - Pro
& Way too many custom boards.
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
I thought mirroring was only used when using the photoresist method for fabbing a PCB.
Logged
www.cmiyc.com - A guide to being an Enginerd
West palm beach, FL
Offline Offline
Sr. Member
View Profile
ive done photo resist, well thats all ive done, i didnt mirror anything though, since its printed on a transparency you just flip that, so in essence you ARE mirroring.
Logged
Scotland
Offline Offline
God Member
View Profile
WWW
If you mirror the image then you can have the ink/toner directly on the resist, cuts down on light leakage. I Print on OHP stock, and remove the toner with acitone when its etched and tested - Only used 3 sheets in the last year or so, and I make boards a couple of times a week.
Logged
Drew.
West palm beach, FL
Offline Offline
Sr. Member
View Profile
yeah i was thinking of investing in a laser printer , but transparency copies at my local staples are  99c  I dont make that many either , if i could find double sided photoresist boards that would be stellar!!!!!! ??
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Quote
If you have a laser printer, why wouldn't you just print directly to a transparency?
Logged
West palm beach, FL
Offline Offline
Sr. Member
View Profile
thats why i said i was " thinking " of investing on a laser printer, i have yet to do so
Logged
Scotland
Offline Offline
God Member
View Profile
WWW
I got an HP1100 from ebay for £10 (Picked it up locally) and its still on its same toner  smiley-grin .
If all you are using it for is for printing occasionally, then just buy a cheap one.
Just get a test print first ! ! !
Logged
Drew.
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
Ah!  You meant, if it is only 99c, why bother with getting your own printer.  Not, if you have a laser printer you'd still be spending 99c.
Logged
Pages: [1]   Go Up
Print
Jump to:
