Offline
Newbie
« on: August 30, 2011, 10:52:44 am » |
hey. im stuck. im trying to make a midi controller with added features of tanspose functions with led interfacing, which all works fine but im struggling in finding a way of making it so i can read more than 1 switch at a time without getting phantom notes playing? i have put pull down resistors in with each switch and a diode. what would you say id do? ive made this code from a mixture of things ive found on the forum int HotPin[6] = {2,3,4,5,6,7}; //Hot (output) pins // int GndPin[6] = {14,15,16,17,18,19}; //Ground (input) pins // int OldKeyPress[36] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // int NewKeyPress[36] = {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}; // int KeyNum = 1; //Identifies the key being read // int MidiNote = 60; //The MIDI note to be played (Middle C is 60) int midnote = 56; // the midi note automatically transposed to int val = 0;// to store state of transpose button up int val1 = 0;// to store state of transpose button down int state = 0;
void setup() { Serial.begin(31250); pinMode(2, OUTPUT); pinMode(3, OUTPUT); pinMode(4, OUTPUT); pinMode(5, OUTPUT); pinMode(6, OUTPUT); pinMode(7, OUTPUT); pinMode(8, INPUT); //transpose up pinMode(9, INPUT); //transpose down pinMode(10, OUTPUT); //leg one of bipolar LED 1 pinMode(11, OUTPUT); // leg two of bipolar LED 1 pinMode(12, OUTPUT); // leg one of bipolar LED 2 pinMode(13, OUTPUT); // leg two of bipolar LED 2 pinMode(14, INPUT); pinMode(15, INPUT); pinMode(16, INPUT); pinMode(17, INPUT); pinMode(18, INPUT); pinMode(19, INPUT); digitalWrite (10, HIGH); digitalWrite (11, LOW); delay (100); digitalWrite (10, LOW); digitalWrite (11, HIGH); delay (100); digitalWrite (10, HIGH); digitalWrite (11, LOW); digitalWrite (12, LOW); digitalWrite (13, HIGH); delay (100); digitalWrite (10, LOW); digitalWrite (11, LOW); digitalWrite (12, HIGH); digitalWrite (13, LOW); delay (100); digitalWrite (12, LOW); digitalWrite (13, HIGH); delay (100); digitalWrite (12, LOW); digitalWrite (13, LOW); }
{ for (int h=0; h <= 5; h++) { digitalWrite(HotPin[h], HIGH); { for (int g=0; g <=5; g++) { KeyNum = (g * 6) + h; //Sets KeyNum to a value from 0 to 31 (C1 is 04) if(analogRead(GndPin[g]) >= 600) { NewKeyPress[KeyNum] = 1; } else { NewKeyPress[KeyNum] = 0; } //Find out if the key if pressed MidiNote = KeyNum + midnote; //Makes C1 on the keyboard middle C if (NewKeyPress[KeyNum] == 1 && OldKeyPress[KeyNum] == 0) //If key is pressed { MidiMessage(0x90, MidiNote, 0x70); //note on, channel 1 } else if (NewKeyPress[KeyNum] == 0 && OldKeyPress[KeyNum] == 1) //If key is released { MidiMessage(0x80, MidiNote, 0x70); //note off, channel 1 } OldKeyPress[KeyNum] = NewKeyPress[KeyNum]; //Set state for next check } } digitalWrite(HotPin[h], LOW); }
{ val = digitalRead( ; //reads button value if (val == HIGH) { midnote = 1 + midnote; state = state + 1; delay (250);}
val1 = digitalRead(9) ; //reads button value if (val1 == HIGH) { midnote = midnote - 1; state = state - 1; delay (250); }
if (state == 0) { digitalWrite(10, LOW); digitalWrite(11, LOW); digitalWrite(12, LOW); digitalWrite(13, LOW);} if (state == 1) { digitalWrite(10, HIGH); digitalWrite(11, LOW);} if (state == 2) { digitalWrite(10, LOW); digitalWrite(11, HIGH);} if (state == 3) { digitalWrite(10, HIGH); digitalWrite(11, LOW); } if (state == 4) { digitalWrite(10, LOW); digitalWrite(11, HIGH); } if (state == 5) { digitalWrite(10, HIGH); digitalWrite(11, LOW); } if (state == 6) { digitalWrite(10, LOW); digitalWrite(11, HIGH); } if (state == 7) { digitalWrite(10, HIGH); digitalWrite(11, LOW); } if (state == { digitalWrite(10, LOW); digitalWrite(11, HIGH); } if (state == 9) { digitalWrite(10, HIGH); digitalWrite(11, LOW); } if (state == 10) { digitalWrite(10, LOW); digitalWrite(11, HIGH); } if (state == 11) { digitalWrite(10, HIGH); digitalWrite(11, LOW); digitalWrite(12, LOW); digitalWrite(13, LOW); } if (state == 12) { digitalWrite(10, LOW); digitalWrite(11, HIGH); digitalWrite(12, LOW); digitalWrite(13,HIGH); } if (state == -1) { digitalWrite(12, HIGH); digitalWrite(13, LOW);} if (state == -2) { digitalWrite(12, LOW); digitalWrite(13, HIGH);} if (state == -3) { digitalWrite(12, HIGH); digitalWrite(13, LOW); } if (state == -4) { digitalWrite(12, LOW); digitalWrite(13, HIGH); } if (state == -5) { digitalWrite(12, HIGH); digitalWrite(13, LOW); } if (state == -6) { digitalWrite(12, LOW); digitalWrite(13, HIGH); } if (state == -7) { digitalWrite(12, HIGH); digitalWrite(13, LOW); } if (state == -8) { digitalWrite(12, LOW); digitalWrite(13, HIGH); } if (state == -9) { digitalWrite(12, HIGH); digitalWrite(13, LOW); } if (state == -10) { digitalWrite(12, LOW); digitalWrite(13, HIGH); } if (state == -11) { digitalWrite(12, HIGH); digitalWrite(13, LOW); digitalWrite(10, LOW); digitalWrite(11, LOW); } if (state == -12) { digitalWrite(12, HIGH); digitalWrite(13, LOW); digitalWrite(10, HIGH); digitalWrite(11, LOW); } } }
//================================================================================================= void MidiMessage(char cmd, char data1, char data2) // { // Serial.print(cmd, BYTE); // Serial.print(data1, BYTE); // Serial.print(data2, BYTE); // } // //=================================================================================================
any help would be much appreciated! thanks sam
