Topic: Connect TSOP1138 to arduino (Read 1 time) previous topic - next topic
opc0de
Hello.I want to make a simple remote control app for my computer for that i just bought a TSOP1138 infrared reciver and i want to connect it to the board. Can you please tell me what resistor should i use here is the data sheet sorry i am a n00b in electornics.
http://coe.uncc.edu/~jmconrad/ECGR6090-2004-01/labs/82006.pdf
Thanks.
retrolefty
No resistor required. The device has three pins, power input goes to arduino +5vdc pin, ground goes to arduino ground pin, signal pin wires to a arduino digital input pin.
Lefty
opc0de
Just connected it to my arduino  i connected it to pin 7 when i make a digitalread on that port i get always 1 why is that ??
retrolefty
It will send data to the arduino when there are valid IR commands being sent to the receiver from a IR remote control. Then you need to use a proper software library to read the signal and convert to the button value being sent by the IR remote control transmitter. What are your expectation of what this device can do?
Lefty
opc0de
I thought the value is 1 when i recive input and 0 otherwise
retrolefty
See figure 3 of the datasheet for output signal response to a valid IR remote control signal. The device only responds to valid 38khz modulated IR data stream, it is not a on and off type of device.
Lefty
opc0de
Thanks for your explanation Lefty so what library should i use to interpret those values thanks
opc0de
I have done it thanks IRemote rocks ;)
sjames1958
I just bought one of these tsop1138. How does one know the frequency of a transmitter.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
