Topic: Can someone identify this symbol in the Arduino schematic? (Read 1 time) previous topic - next topic
s3n4te
Grumpy_Mike
It is a printed circuit pad that is normally shorted out. You can cut the short and then connect it up again with a blob of solder.
RuggedCircuits
Although in this particular case I believe it is used more as a multiple-ground separation technique than a "configurable connection". The designers most likely wanted to keep the USB cable ground somewhat separate from the remaining microcontroller ground (note the ATmega8U2 has separate grounds for this purpose).
The MegaRAM shield: add 128 kilobytes of external RAM to your Arduino Mega/Mega2560
