Topic: Frequency to voltage converter IC (Read 3972 times) previous topic - next topic
jmknapp
Very interesting, Mag--thanks for sharing what you've done.
BTW, for the anti-aliasing filter, I like the tools on this web site from Japan:
http://sim.okawa-denshi.jp/en/Fkeisan.htm
For example, the third-order Sallen-Key LPF which you can implement with 3 resistors, 3 caps and an op amp. Using the Chebyshev selection, looks like if you set the cutoff at 2KHz you could be almost 30dB down at 4KHz.
Joe
Magician
I'm afraid the filter that I need, isn't invented yet.   Roll off so sharp : 30 dB from 1976 to 2000 Hz........
(Nyquist with 4k sampling is 2kHz).  What it would be , 30-th order or something?
The other way, push sampling to higher rate, again , with more memory.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
