Brussels
Offline
Newbie
OtherSounds
« on: September 01, 2011, 05:00:54 am » |
Hi, I want to control variable resistances (2-10-50-100K, 1MOhm) in circuits via my computer (replace a pot by a software control). I have read about digital potentiometers but in my case I have circuits powered at 9v and 12v (and with double power 9v/-9v/0v …) … There used to be digital potentiometers up to 15v in DIP (Dual Inline Package), but they seem discontinued… I suppose there is a case-by-case solution without using digital pots: I have 2 chaos generators circuits (see attached images) where i need computer control over the potentiometers. The one called chua is more simple, there is only one variable resistance to control (1.5 or 2k):
The one called Jerkster is more complex with several variable resistances (R14,R21,R24,R2,R22):
Any solutions for these examples? Any digital pot in DIP package with up to 12v operation available? Any examples with schematics are very welcome! Thanks, Felix
« Last Edit: September 01, 2011, 06:26:17 am by Othersounds »
Logged
0
Offline
Jr. Member
Desenvolvimento de Projeto Eletronico
« Reply #1 on: September 01, 2011, 06:16:28 am » |
You can use CMOS switches and fixed resistance, is not very accurate but it is simpler and more flexible
Logged
Brussels
Offline
Newbie
OtherSounds
« Reply #2 on: September 01, 2011, 08:27:44 am » |
Hello Edsoncan, Thanks for your quick input. There seems to be a lot of types, could you please explain me more in detail witch kind of CMOS switches should I use and point me to some specific models? And how should I connect it to my 0-5v Arduino to control the CMOS switches as a variable resistance? A schematic will be of great help, if someone can make it … Thanks F
Logged
0
Offline
Jr. Member
« Reply #3 on: September 01, 2011, 11:03:55 am » |
Logged
Manchester (England England)
Online
Brattain Member
Solder is electric glue
« Reply #4 on: September 01, 2011, 01:56:20 pm » |
@Edsoncan - if he connects that to a 12 volt circuit he will blow up his arduino. That is only good for 5V circuits.
Logged
Brussels
Offline
Newbie
OtherSounds
« Reply #5 on: September 02, 2011, 03:57:19 am » |
Edsocan, thanks for the schematics! Mike, thanks for pointing that detail ;-)
I'm new to Multiplexers/Switches, and i don't get exactly how they work in this configuration... But are we using it as a voltage controlled resistance? If it's the case, to work with the arduino and a make a 12v control signal, could we use for example something like an uln2003 to feed the max4051 I/O pin?
arduino pwm output 5v--- uln2003 12v--- Max4051 I/O pin 3?
Thanks F
« Last Edit: September 02, 2011, 08:20:29 am by Othersounds »
Logged
Brussels
Offline
Newbie
OtherSounds
« Reply #7 on: September 02, 2011, 12:03:25 pm » |
Logged
Online
Brattain Member
« Reply #8 on: September 02, 2011, 02:59:37 pm » |
Yes that looks fine to me.
Logged
