Topic: XBee Shield to make slow universal USB Extender (Read 9193 times) previous topic - next topic
sbright33
My goal was to control everything like EOS utility on the PC thru the 200m CAT5 cable.  Without wires.  My camera receives IR?  I bet the range is much less than 200m.  Maybe I should just use the USB Host Shield PTP library 2.0 instead?  But then without Canon EOS utility.
http://www.circuitsathome.com/mcu/usb-host-shield-library-version-2-0-released
If you fall... I'll be there for you!
-Floor
Skype Brighteyes3333
(262) 696-9619
daveg360
You're missing the point I was trying to make.  Infrared protocol is many orders of magnitude, easier to handle with an arduino.  What I'm suggesting is that you use RF but use it to send the relevant IR commands that would then be relayed to the camera over IR.
If your system involves lethal voltages/life critical/flamable elements - you probably shouldn't need to ask.
The Arduino != PC.
sbright33
Seems like you can only trigger the shutter via IR.  Maybe focus too?  I can also do that with a short wire between the microcontroller and 2.5mm plug on the camera.  Correct me if I'm wrong.  I'd like to view the pictures remotely!
-Floor
(262) 696-9619
daveg360
I think the simplest option would be something like:
http://www.icron.com/products/usb/collateral/WiRanger_datasheet.pdf
The Arduino != PC.
sbright33
Thanks for your ideas.  You're on the right track!  Except for 2 things both off by an order of magnitude.  300m not 30m would be desired.  $30 not $300 would be better.  I mean in addition to what I already have.  Time to do some coding for my USB shield!  Suggestions?
-Floor
(262) 696-9619
daveg360
So you're hoping to achieve 10 times the range for 1/10th of the cost.......
Is there linux version of the software?
The Arduino != PC.
sbright33
Which software?
I'm just getting started.  I'm new to Uno, but good with C.  Using this Library:
-Floor
(262) 696-9619
bilbo
Alice asked the Chesire Cat, who was sitting in a tree, "What road do I take?"
The cat asked, "Where do you want to go?"
"I don't know," Ali
daveg360
The Canon PC software that you intend to run.  I was thinking along the lines of a beagle board connected to the camera by USB and then just use some sort of VNC to remotely control the beagleboard over your network.  Covering the 300m could then be accomplished using traditional networking technologies.
The Arduino != PC.
sbright33
You may be on to something.  Eyefi might get me 30m tops.  How about the next 270m?  A cheap wifi router up in a tree?  I like both your ideas!  Almost.  It's good we're thinking.
$150 for Beagle.  It only runs Linux?  No Wifi for $150?  3W 500ma power becomes an issue.  I'd like it to stay on for days.  Although I could have it wake and boot when there's a sensor input.  It's getting complicated.  How do I get 300m from Wifi?  More money.  Than only 300m.  Xbee might go nearly a mile for $35.  That's 1000m.  My project needs are not fixed with respect to distance.  Nice try!  Next?
Thanks for your efforts!
-Floor
(262) 696-9619
daveg360
Please supply a complete list of requirements for your project instead of drip feeding in a kind of 20 questions fashion....
I strongly suspect that your budget means that this is completely and utterly hopeless btw.
The Arduino != PC.
sbright33
I don't want to be too specific because I'd like to hear new ideas!  Here it is in general:
$100 in addition to what I already own, UNO, PC, Mifi router, ham radio, Canon 500D
Eyefi doesn't count in the budget because I can make use of that in other ways too, for example.
300m for starters.  I've already got that working with CAT5 and EOS utility, so 200m would be less.
I've already made a circuit to use 110v cable to trigger the shutter no limit for distance.
I'd like to see a still image thru the lense, maybe every 5 minutes?
Thumbnail is only 30K jpg.
As a bonus, slow video and complete control of the camera using v2.0 of the PTP library.
Sorry to be so vague.  I don't mind spending more if I can use it for another project!
I think I've decided what to do, I'm looking for another idea to beat it.
So far I have 2 possibilities to test.  Passing USB data blindly from EOS utility over Xbee.
Or writing my own Arduino code to do one simple function first as v1.0:
Get a thumbnail jpg object from the camera.
http://www.dankulp.com/ptpfs/
Again, I appreciate your effort!
-Floor
(262) 696-9619
daveg360
#27
Sep 07, 2011, 10:15 pm Last Edit: Sep 07, 2011, 10:47 pm by daveg360 Reason: 1
They way I see it for some sort of concept whereby xbee replaces the physical cable in a dumb parrot fashion:
USB spec dictates that a response must be received in 1500ns.  If a response isn't received in time it assumes that there is something wrong.
You want to send the signal 300m.
It takes a radio wave 1000ns to cover 300m at the speed of light and it needs to cover that twice! (there and back)
This leaves you with -500ns..... ermmmm Houston we have a problem
Of course this assumes that an XBee has no delay between receiving a input and transmitting and receiving a signal and outputing.  So in reality it's even worse.
I think it's possible.  However I think you'd need to implement a large amount of the USB protocol and more than likely have the Arduino at the PC end masquerade as the camera and implement it's comms protocols to some degree.  It probably goes a long way to explaining the cost of the commercial devices.
*updated my numbers
The Arduino != PC.
sbright33
The xbee delay is huge compared to 1500ns.  But, it doesn't seem to matter for PTP to my camera.  300m already works as I mentioned.  At 30KByte/sec speeds as well.  I can even unplug each of the data pins and it recovers nicely when I put them back.  How's that for a long delay?
I think it will be impossible for me to trick EOS utility by pretending to be a camera, unless I can blindly repeat the data to the actual camera ignoring the huge delay.  100ms?  Then repeat back the correct response.  It will be easy enough to test when I get the Host Shield.  I will try it in the most simple way possible then give up.  Anyone with this experience to help me code?  I have to stop the PC from sending before the transmit buffer fills.  The same on the other end.
The PTP library will work.  The disadvantage is that I have to manually recode all the features of EOS utility on both ends of the link.  I was hoping to avoid that.  Luckily I don't need any of them.  Except to take a picture and see the thumbnail from the camera.  Can you foresee any problems there?  It's 2 function calls to the v2.0 library!
-Floor
(262) 696-9619
daveg360
I wonder if the device you're using to send the signal down cat5 is doing something clever to get around the maximum response time?
The Arduino != PC.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
