Boston area, metrowest
« Reply #15 on: November 03, 2011, 01:13:58 am » |
"13 to 13, 12 to 12, 11 to 11, 10 to RESET, GND to GND, +5 to +5."
Master pins are listed first, yes?
SF Bay Area (USA)
Strongly opinionated, but not official!
« Reply #16 on: November 03, 2011, 01:46:36 am » |
"13 to 13, 12 to 12, 11 to 11, 10 to RESET, GND to GND, +5 to +5." Master pins are listed first, yes? Yes. Note that the "reset" connection (from pin 10 of the "programmer" Arduino to RESET on the "target" arduino") is the only one that has different signals on each end...
If you're not living on the Edge, you're taking up too much space!
« Reply #17 on: November 03, 2011, 07:28:26 am » |
It should say that in the Readme on Github. Which Sketch do I use for Fusebytes?
If you fall... I'll be there for you! -Floor
Skype Brighteyes3333 (262) 696-9619
SF Bay Area (USA)
« Reply #18 on: November 03, 2011, 09:21:09 am » |
It should say that in the Readme on Github. It says it in the source code. Note that the original intent was that you'd go from the programmer system to a 6pin programmer cable that would then plug into the ISP connector, so the current documentation (in the source code) is worded with that in mind. Which Sketch do I use for Fusebytes? https://github.com/WestfW/fusebytes
« Reply #19 on: November 03, 2011, 09:52:32 am » |
It says that it SHOWS the values. Can we change them?
« Reply #20 on: November 03, 2011, 09:55:01 am » |
@Crossroads - It'll work with my new chips? The hex in the Optiloader sketch is compatible?
SF Bay Area (USA)
« Reply #21 on: November 03, 2011, 10:59:53 am » |
Fusebyte shows the fuse values (and some other info.) You can't change them with a sketch; you need a programmer and programmer software (eg ArduinoISP and AVRDude.)
« Reply #22 on: November 03, 2011, 07:20:40 pm » |
Sbright, Yes, a 328 at 16 MHz is a 328 at 16 MHz.
« Reply #23 on: November 07, 2011, 07:56:49 am » |
Hi I have an Arduino UNO with a fried atmega328 and I replaced it with a 168 I had laying around which already had a bootloader in it. I used the board settings at http://arduino.cc/forum/index.php?topic=28218.0 to enable programming it via the IDE. Now I wanted to program some new 328's on a breadboard of their own. I tried ArduinoISP and WestfW's optiLoader, but with no success.  Any ideas? One possible issue would be that the 168s not running optiboot (got it from sparkfun a year or two ago), but it can be programmed by the aforementioned board settings, so I'm not sure how else to tell.
Dallas
Online
Shannon Member
« Reply #24 on: November 10, 2011, 04:44:32 am » |
After uploading the ArduinoISP sketch, what did you do to disable auto-reset?
