I have been trying to settup a programme on an uno board to measure the time between an object passing up to 4 photosensor arrays. Timing would be triggered on the trailing edge of a pulse generated by the object (a tennis ball) passing a first sensor and then stopped on the trailing edge of a pulse geenrated by a sensor approx. 0.4 m away. Timing will be started again by a third sensor and stopped by a fourth. Eventually I will use the values to calculate velocity and trajectory before and after an impact. I started a previous thread regarding the overall concept, but need some help specifically regarding the timer resolution
http://arduino.cc/forum/index.php?action=printpage;topic=66505.0I found some useful code for detecting pulse edge and measuring time between edges using the micros() function
http://arduino.cc/forum/index.php/topic,70073.msg520999.html#msg520999 This works as it was intended to, but I am noticing inconsistencies in the values returned, I believe due to the code and timer speed. To create more headroom (calculated velocity error will decrease with improved timer resoultion) I would like to use the input capture unit on pin 8 to get down to micorsecond resolution or better. There are many code examples on the forum (thanks to mem), but most are relating to pulse width, rather than period, measurement and have other complicated features that I do not need. I am finding it dificult to adapt working code from these.
I have searched the forum extensively and am understanding the timer1 operation and registers better than I was and have tried to adapt some of mem's code to work in the way I want it to.
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1201890734/12So far I have:
//adaption of mem's timer1 code to measure time from trailing edge to trailing edge twice.
#define icpPin 8 // this interrupt handler must use pin 8
#define NUMBER_PULSES 4 // number of pulses during one cycle of measurement apparatus
volatile uint8_t PulseCount=0; // number of pulses counted
int time1;
int time2;
ISR(TIMER1_CAPT_vect){
if((! bit_is_set(TCCR1B ,ICES1)) && (PulseCount=0)){ // was first falling edge detected ?
TCNT1 = 0; // reset the counter
PulseCount++; // count first pulse
else { // trailing edge at 2nd array detected
if((! bit_is_set(TCCR1B ,ICES1)) && (PulseCount=1)){ // was second falling edge detected ?
time1=ICR1; // record time between 1st and 2nd array
PulseCount++;
if((! bit_is_set(TCCR1B ,ICES1)) && (PulseCount=2)){ // was third falling edge detected ?
PulseCount++;
if((! bit_is_set(TCCR1B ,ICES1)) && (PulseCount=3)){ // was fourth falling edge detected ?
time1=ICR1; // reset the counter
PulseCount++;
TCCR1B ^= _BV(ICES1); // toggle bit value to trigger on the other edge
pinMode(icpPin,INPUT);
PulseCount = 0;
TCCR1A = 0x00; // COM1A1=0, COM1A0=0 => Disconnect Pin OC1 from Timer/Counter 1 -- PWM11=0,PWM10=0 => PWM Operation disabled
TCCR1B = 0x02; // 16MHz clock with prescaler means TCNT1 increments every .5 uS (cs11 bit set
TIMSK1 = _BV(ICIE1); // enable input capture interrupt for timer 1
void loop() // run over and over again
if(PulseCount >= NUMBER_PULSES ){
Serial.println("time 1:");
Serial.println(time1);
Serial.println("time 2:");
Serial.println(time2);
I have been trying to test with a pulse generator, but as soon as the first trailing edge is detected I am getting continuous readings (I am using one shot triggers to get 4 pulses for measurement). So, my PulseCounter and/or If/else statement is not working. I am also a bit usnsure about the line: TCCR1B ^= _BV(ICES1); // I am not sure if I do want toggle TCCR1B. Taking it out doesn't improve the situation.
I am also aware that I have most probably removed some critical code from mem's example, but as a novice I would appreciate any pointers.
Thanks,
Ross
