Topic: pt2258 controller (Read 3233 times) previous topic - next topic
nrajan_2007
byte  VUP = 1;
byte  VDW = 0;
#include <Wire.h>
#include <LiquidCrystal.h>
#include <EEPROM.h>
char    tmp[30];
LiquidCrystal lcd(22,23,18,19,20,21);
unsigned int RC5addr = 0, RC5data = 0;
int8_t tmpdata;
 #define pt2258_addr 0x88
 #define LOGO "SUSEE ELECTRONICS"
 #define   VOLUME   "VOLUME      DB"
 #define   MAX_VDB   (0)
 #define   MIN_VDB   (80)
 #define   INC_VDB   (5)
   int vol;
   int vdb;
   int volume_up = 0;
   int volume_down = 0;
   int buttonState = 0;         // current state of the button
   int lastButtonState = 0;     // previous state of the button
   int button2State = 0;         // current state of the button
   int lastButton2State = 0;
void setup(){
   lcd.begin(16, 2);
   lcd.print("    VOLUME   ");
 Serial.println("Hello world!");
 CLKPR = (1<<CLKPCE);
 CLKPR = 0;
  pinMode(VUP,INPUT);
  pinMode(VDW,INPUT);
  Wire.begin();
 Wire.beginTransmission( pt2258_addr); // transmit to device #4
 Wire.send(0XC0);        // sends five bytes
 Wire.send(0xD7);
 Wire.send(0xE9);  // sends one byte
 Wire.endTransmission();    // stop transmitting
  void selectvolume(int vdb) {
  switch (vdb){
case 0:
   Wire.send(0xD7);
   lcd.setCursor(0,7);
   lcd.print("zero");
case 5:
  Wire.send(0XD7);
  Wire.send(0XE5);
case 10:
 Wire.send(0XD6);
 Wire.send(0XE9);
case 15:
 Wire.send(0XD6);
 Wire.send(0XE5);
case 20:
 Wire.send(0XD5);
 Wire.send(0XE9);
case 25:
 Wire.send(0XD5);
 Wire.send(0XE5);
case 30:
 Wire.send(0XD4);
 Wire.send(0XE9);
case 35:
 Wire.send(0XD4);
 Wire.send(0XE5);
case 40:
  Wire.send(0XD4);
  Wire.send(0XE9);
case 45:
 Wire.send(0XD3);
 Wire.send(0XE5);
case 50:
 Wire.send(0XD2);
 Wire.send(0XE9);
case 55:
 Wire.send(0XD2);              // sends one byte
 Wire.send(0XE5);
case 60:
 Wire.send(0XD1);              // sends one byte
 Wire.send(0XE9);
case 65:
 Wire.send(0XE5);
case 70:
 Wire.send(0XE1);
case 75:
 Wire.send(0XD0);              // sends one byte
 Wire.send(0XE5);
 lcd.setCursor(0,7);
 lcd.print(" max");
 void checkbuttons(){
    buttonState = digitalRead(VDW);
    button2State = digitalRead(VUP);
   if (buttonState != lastButtonState) {
   if (buttonState == HIGH) {
   vdb += INC_VDB;
   vdb = constrain(vdb, 0, 80);
   Serial.print("Counter value: ");
   Serial.println(vdb, DEC);
   selectvolume(vdb);
   lcd.setCursor(0,7);
   lcd.print("     ");
   lcd.setCursor(0,7);
   lcd.print(vdb,DEC);
   lastButtonState = buttonState;
  if (button2State != lastButton2State) {
   if (button2State == HIGH) {
      vdb -= INC_VDB;
   tmpdata = vdb ;
   selectvolume(vdb);
   lcd.setCursor(0,7);
   lcd.print("     ");
   lcd.setCursor(0,7);
   lcd.print( vdb,DEC);
   lastButton2State = button2State;
void loop (){
 checkbuttons();
robtillaart
PLease modify your post, select the code and press the # button so proper tags are included... Looks so much better..
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
(Please do not PM for private consultancy)
B-TECH
Do you have a Schematic for this setup?
Wouldn't mind building this myself..
Thanks.
Computer says "No".. :-P
robtillaart
there is a conflict between comments and code (code always wins)
Code: [Select]
   Wire.begin();
  Wire.send(0xD7);
the comment says 5 bytes or one byte but in fact you are sending 3.
if you divide  vdb by 5 your switch statement will get the numbers 0,1,2,3,4,5 .. 25;
Than enables you to refactor the commands in an array commands, something like
Code: [Select]
byte commands[25][2] = { {D7, E9 }, { , }  .... { , } } // numbers to be filled in
and make a function
Code: [Select]
sendCommand(byte cmd[2])
  Wire.send(cmd[0]);
  Wire.send(cmd[1]);  // sends one byte
The switch will become simpler
Code: [Select]
void selectVolume(int vdb)
  int idx = vdb/5;
  sendCommand( commands[idx] );
  if (vdb == 75)
    lcd.setCursor(0,7);
    lcd.print(" max");
Rob Tillaart
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
