Loading...
Pages: [1]   Go Down
Author Topic: Connecting a nuelectronics li-poly battery pack to an uno  (Read 691 times)
Offline Offline
Newbie
View Profile
Hi, I bought a 5v li-poly backpack from nuelectronics (http://www.nuelectronics.com/estore/index.php?main_page=product_info&cPath=1&products_id=17) but I'm unsure how to connect it.  The data sheet on the site doesn't go into the connection to an arduino uno.  The photos show it connected to what I believe is pin 2 and pin 6 of the ICSP header.
I dont think going via the power socket and the regulator would be a good idea.
Does anyone have one or anyone knowledgable about the rugght connection please? I guess I could use the Vin and gnd pins but that would preclude a sheild.
Thanks in advance,
Steve
Steve.
Logged
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Well the backpack generates a regulated +5vdc output, so you only have three choices of where to wire it to the arduino:
1. Pins 2 & 6 of the ICSP connector pins
2. +5vdc and ground pins on the shield power connector strip.
3. Take a spare USB cable, cut off the PC end, locate the +5vdc and ground wire from the four wires and wire to the backpack's +5vdc/ground output. Then just plug the USB connector into the board to power your arduino.
Lefty
Logged
Offline Offline
Newbie
View Profile
Thanks retrolefty that was fast.  Yeah I dud sone research online after looking closely at the photo but I just wanted to check it was a redo able approach to use the ICSP header. I know a pro framed would use those pins to power the board so it's no different really.
Thanks again.
S
Logged
Pages: [1]   Go Up
Print
Jump to:
