Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Reprogramming the AAG RS485 Weather Station  (Read 3424 times)
Dallas, Texas
Offline Offline
God Member
View Profile
So, if I number the HEs 0-7 like in the attached drawing and they are wired to PC0-PC7 for purposes of this discussion and the top of the drawing is North. Let's also assume that an activated HE has a value of "1", regardless of how we would accomplish that.
Then if the rotor is pointing North, what would be the value of "reading"? If the rotor was pointing South, what would it be?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
The original Dallas 1-wire instrument used a DS2450 4 input A/D converter with 8 reed switches and rotating magnets to determine direction. Someone wrote a sketch to read the speed and direction with an Arduino. I am using it as part of my weather station. Find it here...
http://www.audon.co.uk/1-wire_weather.html
Maybe the new AAG instrument is using a similar method.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Your link didn't work for me. I believe the original 1-wire instrument switched resistors with its reed switches so as to get unique A/D readings for each direction. This one doesn't appear to be switching any resistors.
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Yea the link is dead. I have the sketch and a schematic of the old wind instrument. I will post here.
Logged
nr Bundaberg, Australia
Offline Offline
Tesla Member
Scattered showers my arse -- Noah, 2348BC.
View Profile
WWW
Quote
North = 0 and 4 on = 00010001
South = 4 and 0 on = 00010001
That's my point.
East of north = 0,1 and 4,5 = 00110011
West of south = 4,5 and 0,1 = 00110011
So you have better resolution but again, I don't see how you can tell the difference.
Unless I'm missing something here (it wouldn't be the first time smiley) you have to remove one of the magnets.
_____
Rob
Logged
Rob Gray aka the GRAYnomad http://www.robgray.com
Offline Offline
Tesla Member
View Profile
WWW
Quote
That would make a difference. Still I think removing a magnet would be easier. Maybe add a similar weight to keep the balance.
______
Rob
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Quote
______
Rob
Very good. That's exactly what those inscrutable Chinese did. That gray thing that looks exactly like the other one is a dummy. Only one is a magnet.
I'm proud to say I figured it out before I actually verified it. Like Sherlock Holmes said, whenever you've exhausted all the possibilities, whatever is left, no matter how improbable, is the answer.
So maybe that's what the patent is for.  smiley
Logged
Offline Offline
Tesla Member
View Profile
WWW
He he, do I get a prize smiley
_____
Rob
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
_____
Rob
Sorry, no. smiley Good job, though!
The remaining mystery to me is why they went to such trouble to hide what they are doing. The dummy looks EXACTLY like the real magnet. It's like they had a big batch of defective ceramic magnets to use up. The rotor that operates the HE for wind speed does have two functional magnets and looks identical to the Wind direction rotor. Curiouser and curiouser.
I'm still left with the problem of reprograming the stock chip. Anyone with any suggestions about that please step in.
Logged
Offline Offline
Tesla Member
View Profile
WWW
Quote
I'd buy a $20 programmer like this
http://www.pololu.com/catalog/product/1300
from Pololu or someone (there are a few around) and make up a 6-way to 5-way cable.
______
Rob
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Quote
______
Rob
I might end up doing that but there's no reason why I can't use an Arduino for this project unless the manufacturer has burned the fuses to disable reprogramming.
Logged
Seattle, WA
Offline Offline
Full Member
View Profile
WWW
Unlikely that they're hiding anything.  Perhaps a counterweight? Provided for balance?
Adafruit sells a little ISP programmer (usbtiny) that should do the job nicely.  It's supported directly by avrdude.
BTW, the Bus Pirate that I mentioned yesterday also fulfills this purpose.  Also supported by avrdude.  Just sayin'...
Oh, and my earlier suggestion regarding position is based upon experience with my own AAG weather station.  You really don't get a useful position until it moves.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
Those are all good suggestions. Thank you!
Well, I'm going to call it a night.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
I'm sure it's a counterweight as you suggest but it is made out of the same material that the magnet is made from. Maybe they are readily available from another process/product.
I finally got avrdude/ArduinoISP to talk to the WS but I'll probably order one of the Adafruit programmers to use in the future. The problem was I needed to over-ride the baud rate in avrdude. Coding Badly figured that one out.
The new AAG will be even easier to determine wind direction now that I realize that there is only one magnet. It will work when the vane is stopped as well.
Logged
Dallas, Texas
Offline Offline
God Member
View Profile
I decided to go ahead and bump the clock frequency up to 16 MHz so as soon as a crystal arrives, I'll get back on this project. I'll be using a USBtinyisp and a USB/TTL serial interface instead of an Arduino for programming and communication also, so everything should go smoothly.
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
