Topic: shut down the system (Read 794 times) previous topic - next topic
z_e_u_s
i have one pushbutton it works as on off button. i use a interrupt to turn off the system but when i push the button waits the function ends or stops like ten seconds later it worked  again.
is there any solution like one push on and one push close instantly.
thanks...
AWOL
z_e_u_s
ok then similar solution or advice?
AWOL
The reason for my short answer was lack of detail in the original question.
advice?
Wear sunscreen
nickgammon
... i use a interrupt to turn off the system ...
I'm not familiar with turning off the system. Can you post your code, and your schematic that makes this possible?
...but when i push the button waits the function ends or stops like ten seconds later it worked  again. ...
What happens exactly?
