Loading...
Pages: [1]   Go Down
Author Topic: Needs more outputs  (Read 609 times)
Offline Offline
Newbie
View Profile
Hi all.
This is my first post here. I am in need of some help. I done a small home automation using arduino duemilanove but this is not enough for me since I need more outputs. As I said, need of more outputs, I know that this could be solved by using 2 arduino communicating together but for now I went for the easy way, bought the Arduino Mega. I managed to finalize some coding with the help of google on the duemilanove but I found a problem when I tried to use the same coding for the Arduino Mega. What could be the problem?
In this Post I have included the open source programming of Arduino IDE and processing. If someone could point me out what could be the problem why Arduino Mega is not working with the same code I appreciate a lot.
Is there any other type of programming that I need to do?
Take a look below arduino IDE programming!
int message = 0;     //  This will hold one byte of the serial message
int redLEDPin = 13;   //  What pin is the red LED connected to?
int greenLEDPin = 12;  //  What pin is the green LED to?
int blueLEDPin = 11;   //  What pin is the blue LED to?
int yellowLEDPin = 10;  // What pin is the yellow Led to?
int violetLEDPin = 9;   // What pin is the violet Led to?
int redLED = 0;          //  The value/brightness of the LED, can be 0-255
int greenLED = 0;        // The value brightness of the LED, can be 0-255
int blueLED = 0;        // The value brightness of the LED, can be 0-255
int yellowLED = 0;      // The value brightness of the LED, can be 0-255
int violetLED = 0;      // The value brightness of the LED, can be 0-255
  Serial.begin(9600);  //set serial to 9600 baud rate
void loop(){
    if (Serial.available() > 0) { //  Check if there is a new message
      message = Serial.read();    //  Put the serial input into the message
   if (message == 'R'){  //  If a capitol R is received...
     redLED = 255;       //  Set redLED to 255 (on)
   if (message == 'r'){  //  If a lowercase r is received...
     redLED = 0;         //  Set redLED to 0 (off)
analogWrite(redLEDPin, redLED);  //  Write an analog value between 0-255
if (message == 'G'){  //  If a capitol R is received...
     greenLED = 255;       //  Set greenLED to 255 (on)
   if (message == 'g'){  //  If a lowercase r is received...
     greenLED = 0;         //  Set greenLED to 0 (off)
analogWrite(greenLEDPin, greenLED);  //  Write an analog value between 0-255
if (message == 'B'){  //  If a capitol R is received...
     blueLED = 255;       //  Set blueLED to 255 (on)
   if (message == 'b'){  //  If a lowercase r is received...
     blueLED = 0;         //  Set blueLED to 0 (off)
analogWrite(blueLEDPin, blueLED);  //  Write an analog value between 0-255
if (message == 'Y'){  //  If a capitol R is received...
     yellowLED = 255;       //  Set yellowLED to 255 (on)
   if (message == 'y'){  //  If a lowercase r is received...
     yellowLED = 0;         //  Set yellowLED to 0 (off)
analogWrite(yellowLEDPin, yellowLED);  //  Write an analog value between 0-255
if (message == 'V'){  //  If a capitol R is received...
     violetLED = 255;       //  Set violetLED to 255 (on)
   if (message == 'v'){  //  If a lowercase r is received...
     violetLED = 0;         //  Set violetLED to 0 (off)
analogWrite(violetLEDPin, violetLED);  //  Write an analog value between 0-255
« Last Edit: September 09, 2011, 01:42:52 pm by jasdall » Logged
Offline Offline
Newbie
View Profile
//Processing programming part
import oscP5.*;        //  Load OSC P5 library
import netP5.*;        //  Load net P5 library
import processing.serial.*;    //  Load serial library
Serial arduinoPort;        //  Set arduinoPort as serial connection
OscP5 oscP5;            //  Set oscP5 as OSC connection
int redLED = 0;        //  redLED lets us know if the LED is on or off
int greenLED = 0;        //  greenLED lets us know if the LED is on or off
int blueLED = 0;          // blue  LED lets us know if the LED is on or off
int yellowLED = 0;        // yellow  LED lets us know if the LED is on or off
int violetLED = 0;        // violet LED let us know if the LED is on or off
int [] led = new int [6];    //  Array allows us to add more toggle buttons in TouchOSC
  size(800,100);        // Processing screen size
 noStroke();            //  We don’t want an outline or Stroke on our graphics
    oscP5 = new OscP5(this,8000);  // Start oscP5, listening for incoming messages at port 8000
   arduinoPort = new Serial(this, Serial.list()[0], 9600);    // Set arduino to 9600 baud
void oscEvent(OscMessage theOscMessage) {   //  This runs whenever there is a new OSC message
    String addr = theOscMessage.addrPattern();  //  Creates a string out of the OSC message
    if(addr.indexOf("/1/toggle") !=-1){   // Filters out any toggle buttons
      int i = int((addr.charAt(9) )) - 0x30;   // returns the ASCII number so convert into a real number by subtracting 0x30
      led  = int(theOscMessage.get(0).floatValue());     //  Puts button value into led
    // Button values can be read by using led[0], led[1], led[2], etc.
void draw() {
 background(200);        // Sets the background to a dark grey, can be 0-255
   if(led[1] == 0){        //  If led button 1 if off do....
    arduinoPort.write("r");    // Sends the character “r” to Arduino
    redLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[1] == 1){        // If led button 1 is ON do...
  arduinoPort.write("R");    // Send the character “R” to Arduino
  redLED = 255;        // Sets redLED color to 255, can be 0-255
fill(redLED,70,5);            // Fill rectangle with redLED amount
   ellipse(50, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
                // 50 pixels from the top and a width of 50 and height of 50 pixels
if(led[2] == 0){        //  If led button 1 if off do....
    arduinoPort.write("g");    // Sends the character “r” to Arduino
    greenLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[2] == 1){        // If led button 1 is ON do...
  arduinoPort.write("G");    // Send the character “R” to Arduino
  greenLED = 255;        // Sets redLED color to 255, can be 0-255
fill(greenLED,70,5);            // Fill rectangle with greenLED amount
   ellipse(150, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
if(led[3] == 0){        //  If led button 1 if off do....
    arduinoPort.write("b");    // Sends the character “r” to Arduino
    blueLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[3] == 1){        // If led button 1 is ON do...
  arduinoPort.write("B");    // Send the character “R” to Arduino
  blueLED = 255;        // Sets redLED color to 255, can be 0-255
fill(blueLED,70,5);            // Fill rectangle with greenLED amount
   ellipse(250, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
if(led[4] == 0){        //  If led button 1 if off do....
    arduinoPort.write("y");    // Sends the character “r” to Arduino
    yellowLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[4] == 1){        // If led button 1 is ON do...
  arduinoPort.write("Y");    // Send the character “R” to Arduino
  yellowLED = 255;        // Sets redLED color to 255, can be 0-255
fill(yellowLED,70,5);            // Fill rectangle with greenLED amount
   ellipse(350, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
if(led[5] == 0){        //  If led button 1 if off do....
    arduinoPort.write("v");    // Sends the character “r” to Arduino
    violetLED = 0;        // Sets redLED color to 0, can be 0-255
 if(led[5] == 1){        // If led button 1 is ON do...
  arduinoPort.write("V");    // Send the character “R” to Arduino
  violetLED = 255;        // Sets redLED color to 255, can be 0-255
fill(violetLED,70,5);            // Fill rectangle with greenLED amount
   ellipse(450, 50, 50, 50);    // Created an ellipse at 50 pixels from the left...
Logged
New Jersey
Offline Offline
Edison Member
View Profile
What isn't working? I hooked up a green LED to pin 12 on an UNO and ran your Arduino code as is and could control it from the serial monitor. Then I switched the IDE to Mega 2560 and ran it on my mega; it worked exactly the same, so I don't think the Mega itself is the problem.
Logged
Offline Offline
Newbie
View Profile
Hello wildbill.
I tried another example such as blink Led on the duemilanove and than swapped the IDE to Mega and this worked ok with the example. But when I use the below programming the Mega doesnt work. Very strange. Could be that the oscP5 Library doesnt match for the Mega. With the duemilanove using iphone worked flawless and I'm happy, but now I am limited in outputs and I need an upgrade  smiley
Jason
Logged
California
Offline Offline
Edison Member
View Profile
If you're just needing more digital outputs, why not use shift registers? There's also a shield out there there called the centipede shield that will give you 64 digital pins to work with.
Logged
Pages: [1]   Go Up
Print
Jump to:
