Hi all would be grateful for a bit of help here. I though this bit of my project would be easy but didn't read the eprom page well enough. Anyway it's fairly simple i think, i just don't know how to do it. Basically how do i convert a int to 2 8 bit bytes. I need to store some int's in the eprom but it's only bytes. Their is enough room just i just need pointing in the right direction for a simple way of doing the conversion to the eprom and back again. Cheers
here is the problem
#include <EEPROM.h>
unsigned int Var_1=1000; // 2 bytes
unsigned int Un_Var_1=1000; // ..
unsigned int Var_2=1000;
unsigned int Un_Var_2=1000;
unsigned int Var_3=1000;
unsigned int Un_Var_3=1000;
int Speed=500;
uint8_t Slot_A=0; // 1 byte
uint8_t Slot_B=4;
uint8_t Slot_C=7;
// 17 bytes in all
EEPROM.write(0, Slot_A);
EEPROM.write(1, Slot_B);
EEPROM.write(2, Slot_C);
// EEPROM.write(3, Var_1); // Whats the best way to do this
// presumably i can split it
// into two bytes and then retreve
// it in a similar way
