Topic: SPI read problem, IMU unit ADIS16354 (Read 4365 times) previous topic - next topic
Graynomad
Did you try increasing the delay?
______
Rob
nickgammon
I do not have where or how to check if it works correctly.
If it helped someone, I do not know much about at that.
I don't know here if he is saying it works, it doesn't work, or he doesn't know if it works or not.
More info:
Graynomad
mmichalll
#18
Sep 11, 2011, 02:16 pm Last Edit: Sep 11, 2011, 08:01 pm by mmichalll Reason: 1
My code work.
Reading the values, but I do not know if the correct.
I modifi code, i read x, y, z accel,, x, y, z gyro,, and x,y,z temperature.
I increase delay slightly.
Here is code: code work read values - values ??probably are not all right
Arduino Duemilanove and Tri axis senzor ADIS16354
Datasheet:
http://www.analog.com/static/imported-files/data_sheets/ADIS16354.pdf
pin 10               CS -     SS - vo?ba SPI zariadenia
pin 11               DIN -    MOSI - Master-out, Slave-in - digitálny vstup, slúži na zápis dát z Arduina do senzora
pin 12               DOUT -   MISO - Master-in, Slave out - digitálny výstup, slúži na ?ítanie dát zo senzora do Arduina
pin 13               SCK -    SCLK - Serial clock - nastavenie hodín a frekvencie
#include <SPI.h>
int ss=10; // vyberieme SPI zariadenie, kedže sa používa iba jedno bude stále  táto hodnota nastavená na 10
byte ax, ay, az;
byte gx, gy, gz;
byte tx, ty, tz;
word datax, datay, dataz;
word dataxg, datayg, datazg;
word dataxt, datayt, datazt;
word data;
 Serial.begin (9600);
 pinMode(ss, LOW); // používa sa pin 10
 SPI.begin(); // inicialuzuje sa SPI
 SPI.setDataMode(SPI_MODE3);
 SPI.setBitOrder(MSBFIRST);  // is MSBFIRST correct ??
 // senzor posle najskor MSB (most significant byte) bit ako prvý
digitalWrite (SMPL_PRD, 0x0A);
//SPI.transfer(0x0a);  // set the IMU to read so the next command will get valid data
//SPI.transfer(0x0b);
// Accelerometer read data
//read x accel
digitalWrite(ss,LOW);
delayMicroseconds(160);
ax=SPI.transfer(0x0a);
digitalWrite(ss,HIGH);
datax=(ax<<8);
Serial.print("X Accel: ");
Serial.print(datax, DEC);
Serial.print("\t");
delay(200);
//read y accel
ay=SPI.transfer(0x0c);
datay=(ay<<8);
Serial.print("Y Accel: ");
Serial.print((ay<<8), DEC);
Serial.print("\t");
delay(200);
//read z accel
az=SPI.transfer(0x0e);
dataz=(az<<8);
Serial.print("Z Accel: ");
Serial.println((az<<8), DEC);
delay(200);
// Gyroscope read data
//read x gyro
gx=SPI.transfer(0x04);
dataxg=(gx<<8);
Serial.print("X Gyro: ");
Serial.print(dataxg, DEC);
Serial.print("\t");
delay(200);
//read y gyro
gy=SPI.transfer(0x06);
datayg=(gy<<8);
Serial.print("Y Gyro: ");
Serial.print((gy<<8), DEC);
Serial.print("\t");
delay(200);
//read Z gyro
gz=SPI.transfer(0x08);
datazg=(gz<<8);
Serial.print("Z Gyro: ");
Serial.println((gz<<8), DEC);
delay(200);
// Temperature read data --- ?ítanie teploty
//read x temp
delayMicroseconds(200);
tx=SPI.transfer(0x10);
dataxt=(tx<<8);
Serial.print("X Teplota: ");
Serial.print((tx<<8), DEC);
Serial.print("\t");
delay(200);
//read y temp
ty=SPI.transfer(0x12);
datayt=(ay<<8);
Serial.print("Y Teplota: ");
Serial.print((ty<<8), DEC);
Serial.print("\t");
delay(200);
//read z temp
tz=SPI.transfer(0x14);
datazt=(tz<<8);
Serial.print("Z Teplota: ");
Serial.println((tz<<8), DEC);
delay(200);
Here is the result when the sensor is in peace:
X Accel: 0 Y Accel: 0 Z Accel: -16640
X Gyro: 60928 Y Gyro: -18688 Z Gyro: -27392
X Teplota: -32768 Y Teplota: 512 Z Teplota: -32768
X Accel: 15616 Y Accel: -32768 Z Accel: 13568
X Gyro: 48896 Y Gyro: -17152 Z Gyro: -16640
X Teplota: -512 Y Teplota: -32768 Z Teplota: 1280
X Accel: 32768 Y Accel: 14848 Z Accel: -32768
X Gyro: 9728 Y Gyro: -18688 Z Gyro: -31488
X Teplota: -16640 Y Teplota: -256 Z Teplota: -32768
Here is the result when the sensor moves:
X Accel: 0 Y Accel: 0 Z Accel: 0
X Gyro: 64512 Y Gyro: 5632 Z Gyro: -16384
X Teplota: -21760 Y Teplota: -16384 Z Teplota: -24064
X Accel: 49152 Y Accel: 15616 Z Accel: -16384
X Gyro: 35328 Y Gyro: -1280 Z Gyro: -25088
X Teplota: -14592 Y Teplota: -17408 Z Teplota: -16384
X Accel: 16640 Y Accel: -16384 Z Accel: 14592
X Gyro: 64512 Y Gyro: -1024 Z Gyro: -768
X Teplota: -29440 Y Teplota: -2048 Z Teplota: 0
X Accel: 0 Y Accel: 15616 Z Accel: 0
X Gyro: 0 Y Gyro: 0 Z Gyro: 0
X Teplota: 0 Y Teplota: 0 Z Teplota: 0
X Accel: 0 Y Accel: -16384 Z Accel: 14592
X Gyro: 63744 Y Gyro: 2048 Z Gyro: 0
X Teplota: 0 Y Teplota: -3072 Z Teplota: -12032
Almost the same values.
Here is arduino code  http://arduino.cc/forum/index.php/topic,13298.0.html
There is described the function which reads 8 bits and 16 bits back.(I tried this function but without result)
It is the fifth report.
BTW: I find site http://www.gammon.com.au/forum/?id=10979
I try code from this side modify to my senzor. Here is code:
byte ss=10; //CS pin 10
byte dataxg;
#include <SPI.h>
#define XGYRO_OUT 0x04
void xgyro_out (const byte ss, unsigned int address, byte * dataxg, unsigned int length)
 if (length == 0)  // don't bother if nothing to do
    return;
 digitalWrite (ss, LOW);     // select device
 SPI.transfer (XGYRO_OUT);       // read mode
 SPI.transfer (address >> 8);    // high-order address byte
 SPI.transfer (address & 0x04);  // low-order address byte
 for ( ; length ; --length)
   *dataxg++ = SPI.transfer (0);     // data byte
 digitalWrite (ss, HIGH);    // deselect device
 pinMode(ss, HIGH); // používa sa pin 10
 SPI.setClockDivider(SPI_CLOCK_DIV64);
char buf [100];
xgyro_out (ss, 100, (byte *) buf, sizeof buf);
Serial.print(buf);
Serial.println("\t");
delay(200);
Code work, but results are very wild :(
X Gyro: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÂ
X Gyro:
X Gyro:
X Gyro: ÿ
X Gyro:
X Gyro: ÿ
X Gyro:
X Gyro: À
syedkhyzeraliabidi
Hello everyone,
I have been trying to do something similar to what is written in this post and stuck with the same problem as mentioned here. I am unable to read the sensor data sent back from the sensor. I am using ADIS16210 accelerometer sensor which is connected to Arduino UNO board through SPI pins.
I am trying to get the Product ID of the sensor by accessing its PROD_ID register, According to oscilloscope waveform output of my program I am able to see register address being sent at the MOSI pin as request but on MOSI I always see same output waveform (reflecting 0x40) and on serial monitor it shows 1024 always. please refer to the attached code and let me know how to get the value from sensor and display it on my serial monitor. If you are successful in getting response from Arduino then please le me know how to write code for that part i.e reading bytes from the slave device. I feel that's the tricky part for SPI communication.
As per datasheet  =(I have raised the CS pin after each 16 bit cycle and introduced a delay of 45us to avoid minimum stall time of the sensor. Please refer to page 4 & 7 of the datasheet at below link for more understanding.
http://www.analog.com/en/mems-sensors/low-g-accelerometers/adis16210/products/product.html
Please let me know if you require more information
Thanks,
Syed
digitalWrite(CS, LOW);
  digitalWrite(AVG_CNT,0x09);
  //Before communication starts, the Chip Select pin needs to be set high.
  digitalWrite(CS, HIGH);
delay(45);
SPI.transfer(0x56); // 0x56 for PROD_ID, 0x04 for XACCL_OUT, 0x06 for YACCL_OUT, 0x08 for ZACCL_OUT
SPI.transfer(0);
delay(45);
delay(45);
byte resultHigh = SPI.transfer(0x00);
byte resultLow = SPI.transfer(0x00);
delay(45);
delay(45);
unsigned int result = (resultHigh << 8) | resultLow;
delay(45);
Serial.print(result);
Serial.print('\n');
