Topic: xbee bluetooth (Read 2035 times) previous topic - next topic
DirtGambit
Hi, Im away to go down the bluetooth route for my arduino, I have read a few tutorials and Im under the impression that you have to take out a chip from the arduino to program the xbee. Can i program the bluetooth module with the xbee explorer thus removing the need to remove a chip from the arduino? I have a sparkfun xbee shield and it has a switch on it, im sure i read somewhere with that shield you dont have to remove chips?. Also my laptop doesnt have bluetooth so Ill need a dongle of some sort, which ones would people recommend, there is a £5 one in protopic but I dont know if its reliable as ill be using my device in a house, at least 20m and through some walls.
PaulS
Lets get one thing straight right from the beginning. XBee != bluetooth.
Quote
If you want to use the Arduino with XBee shield to configure the XBee, the chip must be removed so that the data sent to the Arduino is not intercepted by the 328 chip. Instead, the data goes directly to the XBee.
Quote
You can use the USB explorer, instead of a de-chipped Arduino with XBee shield to configure an XBee.
What you can do with it and a bluetooth module, I have no idea.
Quote
Sparkfun sells at least two different (and I mean radically different) XBee shields. Without know which one you have, no advice can be given.
Quote
No, you won't. Standard bluetooth has a maximum range of 10 meters. There are some bluetooth devices that support up to 30 meters, but they have at least one extra 0 in the price.
DirtGambit
Quote
XBee != bluetooth
http://proto-pic.co.uk/bluetooth-module-for-arduino/
ok so you are saying the xbee explorer will configure an xbee but not the bluetooth module?
the shield i have from sparkfun is http://www.skpang.co.uk/catalog/sparkfun-xbee-shield-p-696.html
PaulS
Quote
The USB explorer allows you to connect an XBee or anything that has the same footprint and pinout as an XBee to the PC.
How you configure that devices is completely different. You use X-CTU to configure the XBee. I don't know what, if anything, you use to configure the bluetooth module WHICH IS NOT AN XBEE!!!!
