Loading...
Pages: 1 [2]   Go Down
Author Topic: 2 SD cards in parallel  (Read 2306 times)
0
Offline Offline
Tesla Member
Arduino rocks
View Profile
No chance on SPI, you just have to control each separately with a unique CS line.  In native mode they can be paralleled because they have an addressing scheme which enables commands to be targeted at a single card only, but the only command that works truly in parallel is the ALL_SEND_CIS one which reads the addresses in a manner similar to the OneWire bus's SEARCH ROM command.
Not only is an SD card more complex than the Arduino, they're probably more powerful than early PCs!
Logged
Offline Offline
Newbie
View Profile
Hello,
Sorry to reignite such an old topic, but I'm curious about how something like this works:
http://www.amazon.com/MicroSD-MicroSDHC-Adapter-Converts-Cards/dp/B001RPEJA4
Maybe I misunderstood the original topic, but isn't this adaptor basically running two micro SD cards in parallel?  So it seems it can be done.  Would it be plausible if one wasn't trying to write the same thing to both cards at the same time.  For instance, you have two 64GB cards, and they are put together to act as one 128GB card.
Or is it the case that an adaptor such as that is running the cards in series?  Is there a difference?  I'm interested in running two 128GB cards as one 256GB card in an iPod.
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
The original question was about wiring two SD cards in parallel to get redundancy/mirroring.  This device appears to adapt between the MemoryStick Pro DUO interface and two MicroSD cards of 8GB or less.
I was not aware of any iPod that accepted memory cards (MemoryStick or SD).  What model did you want to do this to?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
No this adapter does not write the SD cards in parallel.  It make two SD cards appear like a twice as large memory stick.
Read the SD spec - it is impossible to access two SD cards in parallel on one SPI bus.  Cards are not synchronous devices.  They go ready at random times and return status at random times.
Logged
Offline Offline
Newbie
View Profile
There are adaptors which will go from an SD card to a ZIF plug.  That's the way to do it.  I found this thread because I was wondering if there was a way to make one of those adaptors use two cards simultaneously.  Kind of like the link I posted, except two full size SD cards (maybe one on top of the other or next to each other.  Depends on space requirements).
With all that said, and I'll open a new topic if it's suggested, but is it possible to make an adaptor like the one I linked to which will serve the purpose I'm looking for?  One which accepts two regular size SDXC cards as one big card.  I apologize for my lack of knowledge of SD cards.
Logged
Miramar Beach, Florida
Offline Offline
Faraday Member
View Profile
@fat16lib: Can you explain this timing a bit? At what point does the Arduino become SPI slave, and the SD card become SPI master? If the SD card is always a slave, it needs to keep quiet until the SPI master tells it to talk.
Quote
It is not as much the SD spec that concerns me here. It is the SPI spec. Does the SD card transmit with the Slave Select HIGH? I don't see an interrupt pin. It doesn't interfere with the w5100 on the same SPI bus. If what you imply is true, they should not be able to coexist. ??
Maybe it is just me, but if the SPI is not synchronous, what is the SCK pin for?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
The SD card is always the slave but it controls timing through the protocol between it and the master.  That's why you need to understand the spec.
For example when you send a command to the card it delays by holding MISO high until it is ready to send status.  The master waits till it get something other than 0XFF.
The protocol is filled with stuff like this that allows the card to control the timing for all operations.  That's why you can't enable two card at the same time and run them in parallel.
SD fat supports multiple cards but only by accessing one card at a time.
Logged
Offline Offline
Faraday Member
View Profile
Quote
So you could possibly access files in both SD cards in one sketch? Just one at a time?
Logged
0
Offline Offline
Edison Member
Arduino rocks
View Profile
Correct. You can have files open on both cards and SdFat will handle it.  See the TwoCards example in the SdFat/examples folder.
SdFat is designed to access any number of cards but each card has a 512 byte buffer.  On a Mega or 1284 you could have a lot of cards with files open on all cards.
Logged
Pages: 1 [2]   Go Up
Print
Jump to:
