Topic: Getting a 5V supply from an Arduino Nano? (Read 1 time) previous topic - next topic
nexekho
Hey!  My Arduino Nano is in the post right now.  I'm planning to build a low-power DSP around it.  Part of this involves biasing the input signal, requiring a 5V source.  For the moment, the Nano is going to be USB only.  What's the best way of sourcing this 5V without soldering a lead from the bottom of the USB connector on the Arduino?  Could just putting an IO pin high do it?  Possibly a waste of an IO pin but if it's the easiest way to get a clean 5V without modifying the board...
http://www.instructables.com/id/Lo-fi-Arduino-Guitar-Pedal/step4/Normalize-the-Input-and-Output/
James C4S
Capacitor Expert By Day, Enginerd by night.  ||  Personal Blog: www.baldengineer.com  || Electronics Tutorials for Beginners:  www.addohms.com
nexekho
Oh - the way I read the overview, that was an input for the IC that bypassed the regulator:
Vin->Regulator->5V->Atmel
So I can just take that pin as a regulated 5V out?  Thanks!
pekkaa
When I power Arduino from USB, I get a little less than 5V (around 4.7V if memory serves me right). When I power Arduino from an external supply, the 5V pin gives almost exactly 5V. So if accuracy is important for your application, you may need to check it out.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
