Loading...
Pages: [1]   Go Down
Author Topic: led doesn't turn off!  (Read 571 times)
Offline Offline
Newbie
View Profile
Code:
  int packetSize = Udp.available();
  if (packetSize)
    packetSize = packetSize - 8;
    Serial.print("received packet of size: ");
    Serial.println(packetSize);
    Udp.readPacket(packetBuffer, UDP_TX_PACKET_MAX_SIZE, remoteIp, remotePort);
    Serial.println("contents:");
    Serial.println(packetBuffer);
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
when i run this code the led connected on ledPin doens't turn off?
is there something i'm missing?
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
It would help if you showed all your code.
The setup function is not shown.
How are you wiring up the LED? What resistor value did you use?
In the heading for this section it says:-
Quote
For problems with Arduino itself, NOT your project
What part of that did you not understand?
Logged
Offline Offline
Newbie
View Profile
Code:
#include <SPI.h>
#include <Ethernet.h>
#include <Udp.h>
//variabelen def:
byte mac[] = {0xAA, 0xAB, 0xAC, 0xAD, 0xAE, 0xAF};
byte ip[] = {192,168,1,199};
unsigned int localPort = 8888;
byte remoteIp[4];
unsigned int remotePort;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
int ledPin = 12;
//setup
  pinMode(ledPin, OUTPUT);
  Ethernet.begin(mac, ip);
  Udp.begin(localPort);
  Serial.println("udp begin");
  Serial.println("setup klaar");
//main()
  if (packetSize)
that's the whole code.
I didn't use a resistor for the LED.
it's connected on GND and pin 12.
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
OK arduino frying time
!!!!!!PUT IN A RESISTOR!!!!!!
see:-
http://www.thebox.myzen.co.uk/Tutorial/LEDs.html
Logged
Offline Offline
Newbie
View Profile
i just read that pin 13 has an 1k resistor. So will you help me if i connect it to that pin?
Logged
Global Moderator
UK
Online Online
Brattain Member
I don't think you connected the grounds, Dave.
View Profile
You shouldn't believe all you read.
Show us your reference.
Logged
Pete, it's a fool looks for logic in the chambers of the human heart.
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
The on-board led wired to pin 13 does have a series on-baord 1k resistor, however that does not protect the shield connector pin 13. So any output pin wired to a shield connector requires a series current limiting resistor if driving LEDs.
Lefty
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
I am helping you. It is possible that you have blown your output pin. Connect the LED and resistor to use another pin and see if that fixes it.
Logged
Offline Offline
Newbie
View Profile
my reference was http://www.arduino.cc/en/Tutorial/BlinkingLED
anyways, I don't have a resistor here (at parents house). So I can't test this until tuesday.
I will report back here then.
Thanks for fast replies, everyone!
Logged
Offline Offline
Brattain Member
View Profile
WWW
Sadly that tutorial is pants but the Arduino team won't take it down. That was true about 4 years ago but the design has changed since then. Sadly it is a trap that most beginners fall into.
Why not just use the on board LED with the built in resistor and see if that goes on and off?
Logged
Austin, TX
Offline Offline
Faraday Member
CMiYC
View Profile
WWW
How long do you think it will take from when the digitalWrite LOW until the next digitalWrite HIGH occurs?  It is very likely the led is being turned off and then back on fast enough that your eye can't see it.
Put an additional delay(1000) after turning the led off, to see if the overall behavior changes.
« Last Edit: September 10, 2011, 06:55:07 pm by James C4S » Logged
www.cmiyc.com - A guide to being an Enginerd
Pages: [1]   Go Up
Print
Jump to:
