Topic: Hot LEDs (Read 4081 times) previous topic - next topic
Grumpy_Mike
Quote
Your finger perceives that radiation as heat
No they don't not at those sort of wavelengths, you fingers peeve them just the same as if they were visible light.
GuitarBuilder
Quote
I beg to differ, Mr. Grumpy!  Typical IR LEDs emit around 940nm and that is used extensively in the medical industry because it does penetrate the skin.  Here's some light reading for you:
http://labs.seas.wustl.edu/bme/wang/epub/2004TD-PMB-Thermal.pdf
Grumpy_Mike
You will notice that the title of that paper says:-
Quote
a theoretical investigation
Have you ever stuck your finger in front of an IR LED? Have you felt it get hotter? Was this hotter than when the same power was given off by a red LED?
Perception is everything in this question.
