Topic: SHT21 float values & dtostrf string? (Read 3968 times) previous topic - next topic
point5
I think I am making a simple mistake but just can't see it !!  Any idea why my float to string conversion is always reporting "2.0" instead of the value output from a SHT21 temp/rh sensor?
My code is:
*  Read the Relative Humidity and Temperature values from SHT21 sensor
*  Clock is Analog pin 5
*  Data is Analog pin 4
#include <Wire.h>
#include <SHT21.h>
#include<stdlib.h>
char temp_str[10];
char  rh_str[10];
float temp;
float rh;
  Wire.begin();
  SHT21.readSensor();
  temp=(SHT21.temp, 2);
  rh=(SHT21.humi, 2);
  dtostrf(temp,6,2,temp_str);
  dtostrf(rh,6,2,rh_str);
  Serial.println("Humidity(%RH): ");
  Serial.println(rh_str); //prints "2.0"
  Serial.println(SHT21.humi, 2); //works
  Serial.println("Temperature(C): ");
  Serial.println(temp_str); //prints "2.0"
  Serial.println(SHT21.temp, 2); //works
  delay(5000);
.... and the output is:
Humidity(%RH):
  2.00
57.50
Temperature(C):
  2.00
25.74
Humidity(%RH):
  2.00
56.42
Temperature(C):
  2.00
25.74
robtillaart
#1
Sep 11, 2011, 10:44 am Last Edit: Sep 11, 2011, 11:02 am by robtillaart Reason: 1
Very wrong code
temp = (SHT21.temp,2);  does not copy with 2 decimals  - you copy/pasted a pattern from Serial print where the 2 is a parameter (#decimals) of the print function for floats.
The statement  (SHT21.temp,2) is a compound statement existing of 2 statements executed from left to right. The return value of the last statement is 2 (as odd as it may sounds) and this value is assigned to temp.
For humidity the error is the same ;)
Check this variation:
#include <Wire.h>
#include <SHT21.h>
#include<stdlib.h>
char temp_str[10];
char  rh_str[10];
float temp;
float rh;
 Wire.begin();
 SHT21.readSensor();
 temp = SHT21.temp;
 rh = SHT21.humi;
 dtostrf(temp, 6, 2, temp_str);
 dtostrf(rh, 6, 2, rh_str);
 delay(5000);
Rob Tillaart
point5
Wonderful, thanks for both the explaination and fix - works great and I can now print to LCD :-)
Cheers.
