Topic: avrdude Apple (Read 4302 times) previous topic - next topic
EmilyJane
Hi Emily... This path you suggest does not work either  =(
You know you can just drag the file from the Finder into your Terminal window and it will automatically write the correct path? Try that.
selfonlypath
oups Emily... YES it works... your suggested path works.... MANY THX XD
EmilyJane
Yay! You're welcome! You don't normally have to include the path to avrdude or the path to avrdude.conf if you want to save yourself some typing.
selfonlypath
I've tried to simplify below line as per suggestion but it says a few things: cannot find conf file then it invokes another avrdude that times out so I guess better I keep this longer typing line
new-host-5:~ selfonlypath$ /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -F -v -patmega1280 -cstk500 -P/dev/tty.usbserial-A6008igj -b57600 -D -Uflash:w:/Users/selfonlypath/Documents/TV/TransVerter1/applet/TransVerter1.cpp.hex:i
EmilyJane
Yep, best keep doing what works!  :)
alvieboy
selfonlypath:
If you wish to know where your file is, open a terminal where your file resides, then type "pwd -P", or in case it does not work, just "pwd"
Then use that absolute path.
baum
Try dragging the file into the terminal window. (i.e. type the command, stopping where you would type in the file name, then drag in the file. the path will automatically show up.)
baum
selfonlypath
Thank you all, so many ways to access the correct file pathname... Everything works perfect now, avrdude just downloads fine my HEX on my arduino mega  8)
baum
Glad to hear it. :) Out of curiosity, what was the correct path?
baum
selfonlypath
maybe read a few posts before for complete command line otherwise, here it is
baum
