Loading...
Pages: [1]   Go Down
Author Topic: Hack "cina" led strip driver and dimmer  (Read 577 times)
0
Offline Offline
Jr. Member
Arduino rocks
View Profile
Hello all,
i'd like to know your thought on this two items.
http://cgi.ebay.it/12v-LED-dimmer-controller-for-led-flexible-strip-ribbon-/390341379823?pt=Led_e_Neon&hash=item5ae228c6ef#ht_1265wt_1141
This one seams to me like a normal potentiometer, i suppose the efficiency is really low with high loads. What do you think about it ?
http://cgi.ebay.it/24Key-IR-Remote-Controller-For-RGB-5050-LED-Light-Strip-/390341379840?pt=Led_e_Neon&hash=item5ae228c700#ht_1309wt_1141
This is a led RGB strip driver, with an IR remote controller. The strange thing is that it works in series with the dimmer controller above. (Sounds a bit strange to me). Btw i suppose (just a random idea) it works with 3 mosfet driven by a pwm signals (8bit maybe). Pwm signals is created by the IR receiver on the white block.
If it works in this way i suppose i can hack it just connecting ground with arduino, (maybe i can also in the same Vin @ 12V) and replace their PWM with arduino's (if, their pwm works at 5v ... )
Did anyone have chance to open and look inside it?
Tnx you in advance
Logged
Montreal
Offline Offline
Edison Member
Per aspera ad astra.
View Profile
WWW
The first item should be a PWM controller, 2 A x 12 V = 24 W, pretty high power to regulate by potentiometer  in small box .
Quote
Sounds strange to me too, as dimmer 2 A, and you need three of them for one remote controller.
I don't think you cam hack it by open a box, black epoxy is the best copyright protector. smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
