Loading...
Pages: [1]   Go Down
Author Topic: RFID 125KHz Reader - Working code  (Read 1991 times)
Offline Offline
Newbie
View Profile
Here is my adapted code for the JsxzLz RFID reader I bought from Ebay (RFID 125Khz Module Kit with module, antenna, 3 TAGs).
Here is a picture of the reader:
And here is the code:
Code:
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
// Re-Modified for Arduino and 125Khz JsxzLz RFID Kit from Ebay by Biohazard
// RFID reader comes with 11 pins: D3 D2 D1 Rest Mcst Gnd L1 L2 PC TX VCC
// We need these to be connected:
// Rest to Arduino pin 2
// Gnd to Arduino GND
// L1 and L2 to the antenna
// TX to Arduino RX0
// VCC To Arduino 5V
int  val = 0;
char code[14];
// 2 digits manufacture code
// 10 digits card code
// 2 digits parity bits
int bytesread = 0;
  Serial.begin(9600);     // RFID reader TX pin, Baud rate: 9600, Data bits: 8, stop bit: 1.
  pinMode(2,OUTPUT);      // Set digital pin 2 as OUTPUT to connect it to the RFID RESET pin
  digitalWrite(2, HIGH);  // Activate the RFID reader
  if(Serial.available() > 0) {            // if data available from reader
    if((val = Serial.read()) == 10) {     // check for header
      bytesread = 0;
      while(bytesread < 14) {             // read 14 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) {  // if header or stop bytes before the 10 digit reading
            break;                        // stop reading
          code[bytesread] = val;          // add the digit
          bytesread++;                    // ready to read next digit
      if(bytesread == 14) {               // if 14 digit read is complete
        Serial.print("TAG code is: ");    // possibly a good TAG
        Serial.println(code);             // print the TAG code
      bytesread = 0;
      digitalWrite(2, LOW);               // deactivate the RFID reader for a moment so it will not flood
      delay(1500);                        // wait for a bit
Thanks for reading, have fun!
Logged
Offline Offline
Newbie
View Profile
Hiii...can I have the data sheet for this module please ???  smiley smiley smiley
Logged
Pages: [1]   Go Up
Print
Jump to:
