Author Topic: Understanding Arduino build process for IDE-haters  (Read 2225 times)
Moscow
I'm writing a Makefile which will allow me to write sketches and program my Arduino no matter what developer tools I use.
From reading http://www.arduino.cc/en/Hacking/BuildProcess it's unclear why Arduino environment does this:
Next, the environment searches for function definitions within your main sketch file and creates declarations (prototypes) for them. These are inserted after any comments or pre-processor statements (#includes or #defines), but before any other statements (including type declarations).
Is this to allow calling functions which are defined further in the source file?
Left Coast, CA (USA)
Measurement changes behavior
Yes, exactly.
Moscow
This is the sketch I'm testing my setup on:
Code: (blink.pde)
#include <SdFat.h>
#include <Wire.h>
#define DS1307 0x68
byte decToBcd(byte val)
    return ((val / 10 * 16) + (val % 10));
void setDateDs1307(byte hour,          // 1-23
                   byte minute,        // 0-59
                   byte second,        // 0-59
                   byte dayOfWeek,     // 1-7
                   byte year,
                   byte month,         // 1-12
                   byte dayOfMonth)    // 1-28/29/30/31
    Wire.beginTransmission(DS1307);
    Wire.send(0);
    Wire.send(decToBcd(second));
    Wire.send(decToBcd(minute));
    Wire.send(decToBcd(hour));
    Wire.send(decToBcd(dayOfWeek));
    Wire.send(decToBcd(dayOfMonth));
    Wire.send(decToBcd(month));
    Wire.send(decToBcd(year));
    Wire.endTransmission();
  pinMode(A0, OUTPUT);
  setDateDs1307(14, 14, 2, 7, 9, 2, 11);
  digitalWrite(A0, HIGH);
  digitalWrite(A0, LOW);
It simply makes a single call via TWI and starts blinking. It requires sdfatlib but does not utilize it.
Makefile I have so far:
Code: (Makefile)
BOARD = atmega328
PORT = /dev/ttyUSB0
SKETCH = blink
ARDUINO-DIR = $(lastword $(wildcard /usr/share/arduino-*))
SKETCHBOOK-DIR = $(HOME)/sketchbook
TMP-DIR = tmp
EXTRA-INCLUDES = $(ARDUINO-DIR)/libraries/Wire/utility/
EXTRA-DEPS = $(ARDUINO-DIR)/libraries/Wire/utility/twi.c
include $(ARDUINO-DIR)/hardware/arduino/boards.txt
CXX = avr-g++
CC = avr-gcc
CXXFLAGS = -mmcu=$($(BOARD).build.mcu) -DF_CPU=$($(BOARD).build.f_cpu) \
   -I$(ARDUINO-DIR)/hardware/arduino/cores/$($(BOARD).build.core)\
   $(foreach dir,$(wildcard $(ARDUINO-DIR)/libraries/*),-I$(dir))\
   $(foreach dir,$(wildcard $(SKETCHBOOK-DIR)/libraries/*),-I$(dir))\
  -I$(EXTRA-INCLUDES)\
  -Os\
  -fno-threadsafe-statics
CFLAGS = $(CXXFLAGS)
.SECONDEXPANSION:
.PRECIOUS: %.deps
.PHONY: clean program
# List object files from .deps file
define list-obj-deps
  $(foreach base,$(shell xargs -L1 basename < $(SKETCH).deps),$(TMP-DIR)/$(base).obj)
endef
# Main sketch file is converted to .cpp
$(SKETCH).cpp: $(SKETCH).pde
@echo Using $($(BOARD).name)
@cat $< | sed -e '1i #include "WProgram.h"' > $@
# Save a list of project dependencies and copy them to TMP-DIR
$(SKETCH).deps: $(SKETCH).cpp $(wildcard *.c) $(wildcard *.cpp) $(wilcard *.h) $(wildcard *.hpp)
@$(CXX) $(CXXFLAGS) -MM $< | sed -e 's/ \\//' -e '$ a.' -e "$ a$(EXTRA-DEPS)" | tail -n +2 | sort | uniq | xargs -L 1 dirname | uniq \
| xargs -L1 -I{} find {} -maxdepth 1 -type f -regex .*\\\(c\\\|cpp\\\)$ > $@
@xargs -L1 -I{} cp {} $(TMP-DIR) < $@
# Intermediate object files for dependencies
# @TODO Update when system libraries update
$(TMP-DIR)/%.obj: $(TMP-DIR)/%
$(CC) $(CFLAGS) $(TMP-DIR)/$* -c -o $@
# @TODO Must somehow expand list-obj-deps call after updating .deps file
$(SKETCH).elf: $(SKETCH).deps $(call list-obj-deps)
$(CC) $(CFLAGS) $(call list-obj-deps) -o $@
%.hex: %.elf $(call list-obj-deps)
avr-gcc -O ihex $< $@
program: $(SKETCH).hex
avrdude -p$($(BOARD).build.mcu)\
-c$($(BOARD).upload.protocol)\
-P$(PORT)\
-b$($(BOARD).upload.speed)\
-U flash:w:$(wildcard *.hex)\
clean:
@rm -frv `hg status --unknown --no-status`
First we make a blink.cpp from blink.pde my adding
Then through the GCC -M option we make a list of dependencies for our sketch:
$ $CXX $CXXFLAGS -MM blink.cpp
blink.o: blink.cpp \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/WProgram.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/wiring.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/binary.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/WString.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/HardwareSerial.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/Stream.h \
 /usr/share/arduino-0021/hardware/arduino/cores/arduino/Print.h \
 /home/bojes/sketchbook/libraries/SdFat/SdFat.h \
 /home/bojes/sketchbook/libraries/SdFat/Sd2Card.h \
 /home/bojes/sketchbook/libraries/SdFat/Sd2PinMap.h \
 /home/bojes/sketchbook/libraries/SdFat/SdInfo.h \
 /home/bojes/sketchbook/libraries/SdFat/FatStructs.h \
 /usr/share/arduino-0021/libraries/Wire/Wire.h
Then according to the BuildProcess
The .c and .cpp files of the target are compiled and output with .o extensions to this directory, as is the main sketch file and any other .c or .cpp files in the sketch and any .c or .cpp files in any libraries which are #included in the sketch.
I assume that we need to gather all .c or .cpp files in any of directories listed by gcc -MM, copy them to our project's temporary lib and compile in objective files using
avr-gcc -c
plus the required include path options and F_CPU definition. With my Makefile I ended up with these files in my tmp/ subdirectory:
blink.cpp
blink.cpp.obj
HardwareSerial.cpp
HardwareSerial.cpp.obj
main.cpp
main.cpp.obj
pins_arduino.c
pins_arduino.c.obj
Print.cpp
Print.cpp.obj
Sd2Card.cpp
Sd2Card.cpp.obj
SdFile.cpp
SdFile.cpp.obj
SdVolume.cpp
SdVolume.cpp.obj
Tone.cpp
Tone.cpp.obj
WInterrupts.c
WInterrupts.c.obj
Wire.cpp
Wire.cpp.obj
wiring_analog.c
wiring_analog.c.obj
wiring.c
wiring.c.obj
wiring_digital.c
wiring_digital.c.obj
wiring_pulse.c
wiring_pulse.c.obj
wiring_shift.c
wiring_shift.c.obj
WMath.cpp
WMath.cpp.obj
WString.cpp
WString.cpp.obj
« Last Edit: September 11, 2011, 03:25:22 pm by Bojes » Logged
Moscow
Now from
These .o files are then linked together into a static library and the main sketch file is linked against this library.
It looks like I need to call
avr-gcc
(without -c) with all these files listed as arguments:
avr-gcc -mmcu=atmega328p -Os -fno-threadsafe-statics   tmp/blink.cpp.obj tmp/Sd2Card.cpp.obj tmp/SdFile.cpp.obj tmp/SdVolume.cpp.obj tmp/wiring.c.obj tmp/main.cpp.obj tmp/WMath.cpp.obj tmp/WInterrupts.c.obj tmp/HardwareSerial.cpp.obj tmp/pins_arduino.c.obj tmp/Tone.cpp.obj tmp/wiring_digital.c.obj tmp/wiring_analog.c.obj tmp/Print.cpp.obj tmp/wiring_pulse.c.obj tmp/WString.cpp.obj tmp/wiring_shift.c.obj tmp/twi.c.obj tmp/Wire.cpp.obj -o blink.elf
After fixing the
__cxa_pure_virtual
error by adding dummy handler
extern "C" void __cxa_pure_virtual() { while (1); }
to my code (-fno-threadsafe-statics doesn't help somehow), I end up with one big .elf waiting to be converted to ihex and flashed:
blink.elf: ELF 32-bit LSB executable, Atmel AVR 8-bit, version 1 (SYSV), statically linked, not stripped
The size of the resulting binary (30K) makes me think that I somehow failed to follow this section:
Only the parts of the library needed for your sketch are included in the final .hex file, reducing the size of most sketches.
And my binary contains all the code from included libraries no matter if this code is used or not. How can I make it include only the code needed to run my code in blink.cpp?
« Last Edit: September 11, 2011, 04:20:57 pm by Bojes » Logged
Moscow
Adding
-ffunction-sections -fdata-sections
options to C/CXXFLAGS in order to force each function reside in its own section coupled with
-gc-sections
linker option allowed me to reach 9.5k hex size compared against 8.3k from Arduino IDE.
« Last Edit: September 11, 2011, 04:40:43 pm by Bojes » Logged
I just made an eclipse plugin that is able to build arduino projects in the same way that the arduino IDE can.  Although I only had to modify the existing source code from the IDE (I didn't have to translate it into a makefile), I did have to find where in the Arduino IDE source was the code that actually does the building.
The process goes something like this:
   Sketch.java's build function is called
   build calls preprocess (this is the function that copies all of the pde files into a single c file and does the prototypes and whatnot.
         preprocess does (creates the main .c file)
         If there are .c or .h files in the project directory it copies them nto the build directory
         it also makes a list of all the imported files and theyre locations (not sure how it knows where they are located)
   build then creates a new compiler and calls the compiler's compile function
      the compile function creates the .o files for all the used libraries.
      then it creates all the core .o files
      then it links all the core.o files into a static library   (core.a)
      then it creates a .elf file from the .o files
      then it extracts eeprom data and makes a .eep file
      then it builds the . hex file
You can find the needed code to see what its doing  in the arduino source... the important files are:
     Sketch.Java,  Compiler.java,  PdePreprocessor.java
Or on github, I have the same files (slightly modified and commented)  at:
https://github.com/Trump211/ArduinoEclipsePlugin/tree/master/src/arduinoplugin
hope this helps (sorry, I don't know much about makefiles)
Moscow
@Trump211
Thank you for sharing the code. Looks like I've missed the .eep generation and your code uses
avr-ar
to combine all object files into core.a file. I wonder if this could the be the reason of my hex being bigger than IDE's.
« Last Edit: September 12, 2011, 04:53:44 am by Bojes » Logged
There is a tutorial for building applications without the Arduino IDE on the Project Struix site that may be helpful.
https://sites.google.com/site/projectstruix/projects/buildwithoutarduinoide
The main site is here:
heres the commands that arduino calls when it builds the AnalogReadSerial example... It will be basically the same for yours, just with different names for the files.  the -DARDUINO=22 doesn't seem to do anything.  Aslo, I replace the /hardware/arduino directory with a ~ for readability
#before anything else happens, the ppde files get put into a cpp file, with the added includes, and prototypes
#makes the .o for the user code
avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=22 -I~\cores\arduino BuildDir\AnalogReadSerial.cpp -oBuildDir\AnalogReadSerial.cpp.o
#builds the core .o files
avr-gcc -c -g -Os -w -ffunction-sections -fdata-sections -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=22 -I~\cores\arduino ~\cores\arduino\pins_arduino.c -oBuildDir\pins_arduino.c.o
(repeats for all the c and cpp files in the core directory)(note that for the cpp files the only difference is avr-gcc becomes avr-g++)
#builds the core.a file from the core .o files
avr-ar rcs BuildDir\core.a BuildDir\pins_arduino.c.o
(repeats for all.o files made in last step)
#builds the .elf file from the user code.o and the core.a
avr-gcc -Os -Wl,--gc-sections -mmcu=atmega328p -o BuildDir\AnalogReadSerial.cpp.elf BuildDir\AnalogReadSerial.cpp.o BuildDir\core.a -LBuildDir -lm
#makes the .eep data
avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 BuildDir\AnalogReadSerial.cpp.elf BuildDir\AnalogReadSerial.cpp.eep
#makes the hex file
avr-objcopy -O ihex -R .eeprom BuildDir\AnalogReadSerial.cpp.elf BuildDir\AnalogReadSerial.cpp.hex
If you have the output that your makefile creates it might be a good thing thing, so that they can be compared
SF Bay Area (USA)
Strongly opinionated, but not official!
Be sure to try compiling your sketch in the arduino IDE in "verbose" mode to see all the steps it is taking.
I'm glad to see you doing this -- I have been contemplating tackling this myself, but since you
are hard at it I'll just wait and make use of what you are doing.  I am eager to escape the IDE
largely because I want to use my own editor, but also because I have been using Makefiles
for longer than I can remember and feel it is healthy to be in touch with the build process.
Keep it up!
Moscow
I think I'll inspect disassembled .hex files from my build and from Arduino IDE to find out the reason behind the size difference.
SF Bay Area (USA)
Don't do that; inspect the .elf files instead.  The .elf files contain MUCH more information (symbols, linenumber info, sections, etc.)  The .hex file is completely stripped except for the actual object code bytes!
Moscow
Yes, right, I confused the two.
