hi to all ,,,
I need your help if you can to design a small system,, if you call tell me what is the required parts to build this project ,,, and from where I have to start . or show me the block diagram any things so I can start from it . and if the code is easy and would not take a time from you can you pls sent it to me , I will be thankful
The project is to
design and construct a prototype for an automatic self-operated Light Rail Transit (LRT) ticket purchase counter system
An LRT railway station has a number of self-operated ticket purchase counters. The
passengers are required to enter the codes of the starting station and the destination
station. The processor should calculate the fare and must display on the four seven-segment in the following format , where the first 2 seven-segment to display the dollar and the second two seven-segment display the cents it’s like that XX.XX
Also, if a passenger enters the starting station code and then changes his mind and leaves.
The system will hang as it will wait for the destination station code to be entered. Under
This circumstance, the following conditions must be implemented:
(a) If a passenger has entered the starting station code and there is no keyboard entry
for the next 15 seconds, the system should reset.
(b) After the display of the station numbers and the fare, the system should wait for
30 seconds and then only reset.
(c) The system should display “READY” initially and after reset.
(d) Also extend the system design to convey the error status.
we can assume that we have 3 station to make it simple A,B and C .
From A to B the cost is 1.30 and from A to C the cost 1.50 , B to C 1.90
