Loading...
Pages: 1 [2]   Go Down
Author Topic: (HELP) Interfacing GSM Modem with Arduino  (Read 2224 times)
Offline Offline
Newbie
View Profile
Blue (arduino right side) - TX
Black (arduino right side) - RX
Red (arduino left side) - 5V
Black (arduino left side) - GND
DB9
Pin 5 - GND
Pin 2 - RX ( Pin 14 of MAX3232)
Pin 3 - TX ( Pin 13 of MAX3232)
Logged
Offline Offline
Newbie
View Profile
Anyone know whats the problem of my system??
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Here is a code snippet of mine that sends a text message of two temperature measurements to my phone.
Code:
Serial.println("AT+CMGF=1");
        delay(2000);
        Serial.println("AT+CMGS=1XXXXXXXXXX,129");
        Serial.print("High Temp = "); Serial.print(hightemp, DEC);
        Serial.print(" Low Temp = "); Serial.print(lowtemp, DEC);
        Serial.println(26,BYTE);
You do need to append either a "129" or "145" on the CMGS command to indicate national or international dialing. I am not sure what your "Serial.print(0x0D,BYTE)" is intended to do. The correct message terminator is a "control-z", which is represented by: "Serial.println(26,BYTE)." You do need the println format to send a carriage return/line feed.
« Last Edit: September 20, 2011, 03:28:42 pm by arcs_n_sparks » Logged
Offline Offline
Newbie
View Profile
Thanks i'll try that out.
But from what i've tested the computer requires a 5wire connection (RX, TX, RTS, CTS and GND) and the arduino can only support 3.
Anyone can enlighten me on how to interface it with a arduino?
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
RTS and CTS are for flow control. They are not absolutely required, and you can configure the PC UART not to require them (I believe that is the default condition).
« Last Edit: September 24, 2011, 07:17:27 pm by arcs_n_sparks » Logged
Pages: 1 [2]   Go Up
Print
Jump to:
