Topic: Prototino ATMega328 Kit + Ethernet (Read 1 time) previous topic - next topic
tyler785
What is the best way to use a Prototino ATMega328 Kit and ethernet?  Are there any kits other than the ethernet shield that allows you to directly solder it to the Prototino?
PaulS
Quote
What is a Prototino ATMega328 Kit? Got a link?
Quote
The great thing about shields is that they do not need to be soldered on.
tyler785
Prototino is this: http://www.makershed.com/ProductDetails.asp?ProductCode=MKSKL4
The point of it is to not use your standard Arduino and allow you to solder your project together permanently.  Using this would not allow you to easily use any shield.
liudr
Most shields only work on arduino UNO or compatible boards anyway. Is there any function in your project you will need a shield to accomplish?
Serial LCD keypad panel,phi_prompt user interface library,SDI-12 USB Adapter
tyler785
I have a simple project that I may want to make it more permanent in the future.  Currently it is build on a Uno with an ethernet shield on it.  I was thinking about using the Prototino to make it permanent but have not found a simple way to integrate ethernet to it as the shield is made to be used with the long pin headers for an Uno or other similar board.
liudr
What about:
http://www.inmojo.com/buy/prototyping/
phi-connect, Aussie,and quick shields could all be used to connect to arduino or a shield and then wire to the Prototino.
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
