Loading...
Pages: [1]   Go Down
Author Topic: Connecting 2-pin button  (Read 1791 times)
Offline Offline
Full Member
View Profile
Hello all, I've seen lots ot tutorials explaining how to connect a button to Arduino and I've even played with some, but they always had 3 or 4 pins. Recently I've aquired these tasters and I don't really know how to connect them properly to Arduino since they've got only 2 pins. Suggestions anyone? Here's the picture:
Logged
United Kingdom
Online Online
Faraday Member
View Profile
WWW
Connect one side of the button to Gnd and the other side to an Arduino pin. Configure that pin as a digital input with pullup enabled:
 pinMode(pinNumber, INPUT);
 digitalWrite(pinNumber, HIGH);
then if the button is push-to-make, a digitalRead from that pin will return LOW when the button is pressed, HIGH when it is not pressed. If the pushbutton is press-to-break, this will be reversed.
Logged
Formal verification of safety-critical software, software development, and electronic design and prototyping. http://www.eschertech.com
Offline Offline
Full Member
View Profile
AWESOME, I don't even need resistors. Thanks a bunch.
Logged
United Kingdom
Online Online
Faraday Member
View Profile
WWW
PS - I should have said don't use digital pin 0, 1 or 13. Any other pin will do.
Logged
Offline Offline
Newbie
View Profile
Having a similar issue and I am very new to this. I have same type buttons/switches (Normally Open), though I want to connect 4 of these to a Teensy 2.0 board. What kind of connection would I need?
I have read some other postings and they say this:
ButtonA = 1pin to 10ohm resistor to ground + pin on board, 1 pin to 5V
ButtonB = repeat similar
ButtonC= repeat similar
ButtonD= repeat similar
Ideas?
« Last Edit: September 28, 2011, 12:22:42 am by naweston » Logged
Topsham, Vermont USA
Online Online
Edison Member
... in The Woods In Vermont
View Profile
WWW
Quote
10 "K"  (10,000 ohm) resistor and this is OK...
Logged
Regards, Terry King terry@yourduino.com  - Check great prices, devices and Arduino-related boards at http://YourDuino.com
HOW-TO: http://ArduinoInfo.Info
United Kingdom
Online Online
Faraday Member
View Profile
WWW
Ideas?
It's simpler to connect each button between ground and an Arduino pin and enable the internal pullup resistor, as I said before.
Logged
Offline Offline
Newbie
View Profile
So no physical resistor nor a lead to 5V, correct?
Just 1pin to I/O pin, 1pin to GRN?
Logged
United Kingdom
Online Online
Faraday Member
View Profile
WWW
That's correct. Do a digitalWrite(pin, HIGH) to each of the input pins, that will turn on the internal 20K pullup resistors on those pins.
Logged
Offline Offline
Full Member
View Profile
Sorry for the bumping, I haven't been around, but why not 0 and 1?
Logged
South Louisiana
Offline Offline
Full Member
Arduino rocks
View Profile
Those are the internal serial port. This is the same port used when you upload sketches.
Technicaly they can be used but you would have to disconnect them every time you upload a sketch so its much easier as a beginner to avoid them if possible.
Logged
Pages: [1]   Go Up
Print
Jump to:
