Loading...
Pages: 1 [2] 3 4   Go Down
Author Topic: Analog pin problems  (Read 2026 times)
London
Offline Offline
Full Member
Yes, we can (solder)!
View Profile
Since my last post I've been experimenting with different pull-down resistor and pot values. Unfortunately, whatever resistor I use the connections effect each other. I came to the conclusion that I have to break the connection between the pull-down and the analog pin the moment I connect a voltage source. Alas, I tested the concept on the breadboard and it works (I simply removed pull-downs from the connected analog pins). I wonder, is there a plug socket that breaks the existing connection between the pull-down while creating a new connection? Or should I add a transistor switch driven by the voltage source inserted?
Logged
Pittsburgh, PA, USA
Offline Offline
Faraday Member
I only know some basic electricity....
View Profile
When switching analog inputs quickly, SOP is to sample the new pin twice and ignore the first read.
Logged
Examples can be found at Learning in the Main Site and at the Playground
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
Yes.  Many mono and stereo phone jacks (like for headphones) have a switch which opens when you plug in a cable.  In normal use this disconnects the speaker(s) when you plug in headphones but can be used for your pull-down resistors.
Logged
London
Offline Offline
Full Member
View Profile
Brilliant! Thanks!
Logged
Manchester (England England)
Offline Offline
Brattain Member
Solder is electric glue
View Profile
WWW
Quote
That is because the values you are using are too large.
If the impedance of anything fed into the analogue inputs is greater than 10K, there is not enough time to charge the sample capacitor before the sample is taken.
So can you lower your impedance?
Your solution of shorting it out will only result in you not getting the right value the first time you take the reading although you might miss this.
Logged
London
Offline Offline
Full Member
View Profile
I've tried 1 ohm to 1 M reistors and some in between. No succes. What are you suggesting, Mike?
Logged
London
Offline Offline
Full Member
View Profile
I guess if I add a short delay, it would should be all right.
Logged
London
Offline Offline
Full Member
View Profile
[quote author=Grumpy_Mike link=topic=72289.msg597190#msg597190 date=1321357387
[/quote]
Sorry Mike but I'm still struggling with the idea of impedance. Can you give me an example? And what does that mean that the analog inputs have great impedance? What are the implications of these?
Logged
London
Offline Offline
Full Member
View Profile
If the analog input has high impedance, what happens when you add a low and a high impedance source?
Logged
London
Offline Offline
Full Member
View Profile
If an analog input has high impedance (whatever it means), does it mean it allows more current through than a low impedance input? Any help to shed some lights on this issue would be appreciated!
Logged
London
Offline Offline
Full Member
View Profile
BTW, does it help if I set the internal pull-ups? Are they any better or reliable than the external ones?
Logged
Offline Offline
Brattain Member
View Profile
WWW
Quote
No.
An impedance is like a series resistance to the voltage source. In your case the voltage source is a resistance so it means the value.
Quote
No... the delay you need is between the switching of the multiplexer and the grabbing of the sample. This can only be acheaved by taking two readings of the same panel.
Quote
I've tried 1 ohm t
If you truly have then you have something else that is seriously wrong. Can you provide a schematic of what you have.
Logged
London
Offline Offline
Full Member
View Profile
Sure!
[/URL][/img]
Logged
London
Offline Offline
Full Member
View Profile
][URL=http://s125.photobucket.com/albums/p66/alkopop79/?action=view&current=ardui.jpg][/url]
Logged
London
Offline Offline
Full Member
View Profile
Grrrrrrrrrrrrr, direct link here:
http://tiny.cc/hwg2r
Logged
Pages: 1 [2] 3 4   Go Up
Print
Jump to:
