Topic: conflicting timer issue in libaries? (Read 702 times) previous topic - next topic
gaggenau
hi im working on a dmxtester device.
i want to use a single potentiometer to set both channel and dmxvalue .a button to change between set channel mode and dmxvalue mode.
to display the channel and dmx output value I want to use the nootropicdesign digitshield wich is a four digit 7 segemt display shield.
i have now start writing the code but when im compiling the sketch i get a strange error message:
DigitShield/DigitShield.cpp.o: In function `__vector_9':
/Users/GET/Documents/Arduino/libraries/DigitShield/DigitShield.cpp:286: multiple definition of `__vector_9'
DmxSimple/DmxSimple.cpp.o:/Users/GET/Documents/Arduino/libraries/DmxSimple/DmxSimple.cpp:141: first defined here
it seems like the error has to do with the libraries im using. could it be a timer issue?
any ideas how to solve it?
the code :
Code: [Select]
#include <DmxSimple.h>
#include <DigitShield.h>
int sensorPin = A0;    // select the input pin for the potentiometer
int DmxValue = 0;  // variable to store the value coming from the sensor
int buttonState = 0;         // variable for reading the pushbutton status
int ChannelValue=0;
int RawValue1=0;
int RawValue2=0;
const int buttonPin = 7;
    DmxSimple.usePin(6);
    DigitShield.begin();
   pinMode(buttonPin, INPUT);
    if (buttonState == HIGH) {
    // set Dmx channel
    RawValue1 = analogRead(sensorPin);
    ChannelValue = map(RawValue1, 0, 1023, 1, 512);
    DigitShield.setValue(ChannelValue);
  else {
    // Set DMX value
  RawValue2 = analogRead(sensorPin);
      DmxValue = map(RawValue2, 0, 1023, 0, 255);
    DigitShield.setValue(DmxValue);
  DmxSimple.write(ChannelValue, DmxValue);
MarkT
Do you have sourcecode for the libraries?  Look for ISR routines for the same interrupt vector - if they both define an interrupt routine for the same interrupt that would clash.
gaggenau
with help from Michael at nootropic design who made the digitshield and its library i solve the timer issue. the segment shield is now using timer1 instead of timer2.
here is the code that needs to be change in the digitshield library:
Code: [Select]
   // TIMER1
  // Disable the timer overflow interrupt
  TIMSK1 &= ~(1 << TOIE1);
  // Set timer1 to normal mode
  TCCR1A &= ~((1 << WGM11) | (1 << WGM10));
  TCCR1B &= ~((1 << WGM13) | (1 << WGM12));
  // Disable compare match interrupt
  TIMSK1 &= ~(1 << OCIE1A);
  TIMSK1 &= ~(1 << OCIE1B);
  // Prescalar is clock divided by 128
  TCCR1B &= ~(1 << CS12);
  TCCR1B &= ~(1 << CS11);
  TCCR1B |= (1 << CS10);
    // Start the counting at 0
  TCNT1 = 0;
  // Enable the timer2 overflow interrupt
  TIMSK1 |= (1 << TOIE1);
the overflow ISR need to be change to this:
Code: [Select]
  ISR(TIMER1_OVF_vect) {
  TCNT1 = 0;
  for(int i=0;i<nDigitShields;i++) {
    digitShields[i]->isr();
the DmxTester uses a button,slider potentiometer, Nootropic design digitshield , and a sn75176 for the rs232 ttl to rs485 conversion.
and here is the code:
Code: [Select]
This code was made by Gustaf Gagge with help to change to timer 1
in the digitshield library from Michael  at Nootropic design who also wrote the digitshield library.
modify the digitshield libary with this in the initialization part
file to modify: DigitShield.cpp
   // TIMER1
  TCNT1 = 0;
  TCNT1 = 0;
int ChannelValue=0;
int RawValue1=0;
int RawValue2=0;
    DmxSimple.usePin(6);// as standard the DmxSimple uses D3 but for this we need D7
   digitalWrite(buttonPin, HIGH);
  int val = digitalRead(buttonPin);
    if (val == LOW) {
    // set Dmx channel
  else {
    // Set DMX value
Confirm your email address
Thank you for subscribing!
Arduino
via Egeo 16
Torino, 10131
Italy
