Maastricht, The Netherlands
Offline
Jr. Member
Techno!!
« on: September 15, 2011, 03:38:34 am » |
Hello people!! For a project I need to know the time in Arduino. Therefore I've used a DS1306 RealTimeClock. Everything is working okay, I can see time, date, etc... on my Arduino. the (integer) variable HOUR keeps the hour of the day (0 to 23) the (integer) variable MINUTE keeps the minutes (0 to 59) the (integer) variable SECONDS keeps the seconds (0 to 59) So for example: (15:55:11) HOUR = 15 MINUTE = 55 SECONDS = 11 Now I want to turn a LED on after 15 minutes. How do I have to program this? ( I have to compare time, but how? ) Thanks in advance  Greetings from the Netherlands, Atmoz
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #1 on: September 15, 2011, 04:25:55 am » |
How do I have to program this? We'd really have to see the code you have now. If you have three int variables, onHour, onMin, onSec, what contain the time that the LED was turned on, you can determine when to turn it off, by adding to those variables. If the off time is 15 minutes after the on time, add 15 to onMin to get the off time. Of course, you'll need to make sure that offMin doesn't exceed 60. If it does, subtract 60, and add 1 to offHour. Of course, then you'll need to make sure that offHour remains reasonable.
Logged
Offline
Jr. Member
Techno!!
« Reply #2 on: September 15, 2011, 04:37:29 am » |
Hi PaulS, Thanks for the fast reply!! That is the problem indeed. I have to "manually" check if it's not exceeding 59... I was hoping that there was a "smart" or easy way to "compare" time and/or date, just like in Visual Basic or so  Unfortunately I don't have any code regarding this. The only code I have is the one that nicely fills the 3 INT's (HOUR, MINUTES, SECONDS) The "comparison" code isn't there. That's the number 1 reason from this topic. Thanks again, Atmoz
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #3 on: September 15, 2011, 04:57:08 am » |
int onHour = 15; int onMin = 55; int onSec = 11;
int offHour = onHour; int offMin = onMin + 15; int offSec = onSec;
if(offMin > 59) { offMin -= 60; offHour++; }
if(offHour > 23) // Or 11, if using 12 hour mode offHour -= 24; // Or 12... Nothing automatic, but not all that difficult, either. Now, if you want to make the LED stay on for 1 hour, 13 minutes, and 27 seconds, it becomes a little more complicated, but only marginally so.
Logged
Offline
Jr. Member
Techno!!
« Reply #4 on: September 15, 2011, 05:09:12 am » |
Thanks again PaulS  That looks very nice!! Why does it become a little more complicated if I want to turn on the LED 1:13:27 on? Only because you have to "test" also the seconds, right? Or do I miss something important? In the meanwhile I figured something else: 13:55 hour if you want to add 15 minutes you do: 13x60 (to make the hours also minutes) then you add the minutes you already have AND the 15 minutes you want to add At the end you got ((13x60 )+ 55 + 15) = 850 850 / 60 = 14,166666667 14 are the hours 0,166666667 x 60 are the minutes (14:10 hours) But then I have to figure out how I can fill variable HOUR with all the things before the comma, and variable MINUTES with al the thing after the comma... (and I don't know how to do this) So your idea is better  Thanks!!
Logged
Seattle, WA USA
Offline
Brattain Member
Seattle, WA USA
« Reply #5 on: September 15, 2011, 05:31:54 am » |
Only because you have to "test" also the seconds, right? Or do I miss something important? You need to increment three variables, and perform three tests - seconds, then minutes, then hours. So, more complex, but, as I said, only marginally so.
Logged
Global Moderator
Melbourne, Australia
Offline
Shannon Member
Lua rocks!
« Reply #6 on: September 15, 2011, 05:58:13 am » |
You don't need to know the time-of-day to turn on an LED after 15 minutes, any more than you need to know the time-of-day to time a 3-minute egg. You can use the millis () function to find when 15 minutes are up.
Logged
Offline
Jr. Member
Techno!!
« Reply #7 on: September 15, 2011, 06:08:26 am » |
Only because you have to "test" also the seconds, right? Or do I miss something important? You need to increment three variables, and perform three tests - seconds, then minutes, then hours. So, more complex, but, as I said, only marginally so. Okay! Got it. Thanks!! You don't need to know the time-of-day to turn on an LED after 15 minutes, any more than you need to know the time-of-day to time a 3-minute egg.
Also a nice option indeed!! But after +/- 50 days the millis counter goes back to 0, so in that case you also have to "test" the value to make a good timing to power on the LED. It's a lot simpler and easier though! Thanks both  Atmoz
Logged
Grand Blanc, MI, USA
Offline
Edison Member
"We're a proud service of the Lost Electricity Reclamation Agency"
« Reply #8 on: September 15, 2011, 07:44:55 am » |
Actually not! One more alternative is the Time library, the time_t data type is seconds since 01Jan1970.
Logged
Offline
Jr. Member
Techno!!
« Reply #9 on: September 15, 2011, 08:47:21 am » |
Actually not! How do you mean? From: http://arduino.cc/en/Reference/Millis Returns the number of milliseconds since the Arduino board began running the current program. This number will overflow (go back to zero), after approximately 50 days. One more alternative is the Time library, the time_t data type is seconds since 01Jan1970. Thanks!! Also a good one. That must be a large number in these days  Now I'm stuck again: How can I "test" a number let's say 11 if it's at least 2 digits/counts away from another number? So if I have a = 11 and b = 14 OR for example b = 10 how can I "check" if a is > b+2 OR a < b-2 At the moment I use if (SprMinute< minuten +2 || SprMinute> minuten -2){ but this doesn't seem to work. This is also for "checking" the time... Thanks!! Atmoz [edit] I found it. I had to swap + and -
« Last Edit: September 15, 2011, 09:10:57 am by Atmoz »
Logged
Offline
Sr. Member
« Reply #10 on: September 15, 2011, 10:29:22 am » |
850 / 60 = 14,166666667 14 are the hours 0,166666667 x 60 are the minutes (14:10 hours) But then I have to figure out how I can fill variable HOUR with all the things before the comma, and variable MINUTES with al the thing after the comma... (and I don't know how to do this) So your idea is better  Thanks!! Look at the modulous "%" operator. It will do exactly what you want. 850 / 60 = 14 hours (using ints no decimals rounds down) 850 % 60 = 10 minutes
Logged
Offline
Edison Member
« Reply #11 on: September 15, 2011, 11:29:38 am » |
Actually not! How do you mean? From: http://arduino.cc/en/Reference/Millis Returns the number of milliseconds since the Arduino board began running the current program. This number will overflow (go back to zero), after approximately 50 days. Of course it does overflow, but because it's an unsigned (long) integer any two values can be subtracted and will give the right answer, as long as you're not trying to time a delta of more than ~50 days. One more alternative is the Time library, the time_t data type is seconds since 01Jan1970. Thanks!! Also a good one. That must be a large number in these days  Yep, about 1316107515 right now ... see http://www.unixtimestamp.com/. There are parties when it hits a notable value, like 1234567890. Now I'm stuck again: How can I "test" a number let's say 11 if it's at least 2 digits/counts away from another number? So if I have a = 11 and b = 14 OR for example b = 10 how can I "check" if a is > b+2 OR a < b-2 At the moment I use if (SprMinute< minuten +2 || SprMinute> minuten -2){ but this doesn't seem to work. This is also for "checking" the time... Thanks!! Atmoz [edit] I found it. I had to swap + and -  Or use the abs() function.
Logged
Offline
Jr. Member
Techno!!
« Reply #12 on: September 15, 2011, 11:34:31 am » |
Thanks for the explanation!! Also thanks for that one. I had looked at this before, but didn't directly understand how it works. I'll have a look at it tomorrow!! @Delta_G THANKS! That I was searching. very very long ago I already uses this, but I was completely forgotten it. Everything is working how it should be. Very nice  Thanks  Atmoz
Logged
Tucson, AZ
Offline
Newbie
« Reply #13 on: September 15, 2011, 06:15:35 pm » |
Anyone have advice for a working clock? I have an RTC module, but I don't know how to program it to remember time.
Logged
Offline
God Member
« Reply #14 on: September 15, 2011, 06:57:01 pm » |
The RTC module needs a battery to "remember" time. Once you insert the battery, it will remember time (and keep it ticking) even when turned off. Just make sure you don't re-write a bad time in your setup() function!
Also, I've found that, when dealing with timed events, it's better to compare seconds intervals than specific times. So, for example, if you want to turn something on 15 minutes after something else, then calculate the seconds (epoch) value for the first time, add 15*60, and then when the seconds (epoch) value goes past that value, you turn on the thing. You can check this each time the timer changes, and there's no chance you will miss it -- even if the chip is turned off, and then turned on in the middle of the timer interval, the check will then see "oh, it's greater than start time -- turn on!"
Logged
