Topic: is there a library for the RN-XV WiFly Module? (Read 5267 times) previous topic - next topic
thatdude624
so, I was looking for some way to allow my device to be remotely controlled via a browser, or let it connect to the internet in some way, and I found this: http://www.netram.co.za/Wireless/RN-XV-WiFly-Module.html
it seems to be a very cheap WiFi system, and since I own a shield witch has an Xbee socket, this seemed perfect.
problem is, I don't think you can just use the Ethernet library with it. I did find this: http://forum.sparkfun.com/viewtopic.php?f=13&t=21846 but that seems to be for the shield version.
is there a library that is capable of this? also, I might need some HTML for the UI, as the code for the Ethernet may not work.
thanks.
daleth
Yes, you can use that library, I did in my tutorial on the RN-XV:
http://log.liminastudio.com/programming/getting-started-with-the-rn-xv-wifi-module-node-js
Here's another tutorial that might help:
http://log.liminastudio.com/itp/physical-computing/using-the-rn-xv-wifi-module-as-a-remote-switch
Dermiste
Hello there!
Has anyone managed to get this working properly ?
I had to modify the library itself to modify a few return types, and it does not seem to work fine at this moment.
When I try to join a network (WEP) it does not work. If I create one with my HTC (WPA) it does not work as well and I get series of "$$$" ...
Anyone?
