Pages: [1]   Go Down
Author Topic: Software reset doesn't work on my Diecimila compatible board  (Read 965 times)
0
Offline Offline
Newbie
Arduino rocks
View Profile
I haved designed a board compatible with Diecimila(ATmega168). I do connect DTR pin of FTDI chip to reset pin of ATmega168. However I found that I still need to press the reset button after clicking upload icon in arduino environment.
My question is: how to upload the firmware without pressing reset button?
Thanks for any comments or suggestions.
HHPP
Logged
Massachusetts, USA
Offline Offline
Tesla Member
View Profile
You could check the Diecimilla schematics and see where your circuit differs from theirs.
http://arduino.cc/en/uploads/Main/Arduino-Diecimila-schematic.pdf
The schematic shows both DTR# and RTS# from the FTDI FT232RL chip being connected to the Reset line through resistors marked "100_NM" (whatever that means).
Logged
Send Bitcoin tips to: 1L3CTDoTgrXNA5WyF77uWqt4gUdye9mezN
Send Litecoin tips to : LVtpaq6JgJAZwvnVq3ftVeHafWkcpmuR1e
Left Coast, CA (USA)
Offline Offline
Brattain Member
Measurement changes behavior
View Profile
Quote
The "NM" means not mounted, as in not installed in production units.
Lefty
Logged
Offline Offline
Brattain Member
View Profile
HHPP
Many other designs also use the simple .1ufd series cap between FTDI DTR/ pin and the AVR reset pin successfully. Can you post a drawing of your design to see what might be preventing auto-reset function from working?
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
I have attached my schematic capture.
Please let me know if you find anything wrong. Thank you Guys!
Logged
Offline Offline
Brattain Member
View Profile
Try it without C-29. And if R-16 isn't just a piece of wire, replace it with a piece of wire.
Lefty
Logged
0
Offline Offline
Newbie
Arduino rocks
View Profile
Hi Lefty,
Thank you very much for your suggestion. I removed C29 and it works!!
Regards,
hhpp
Logged
"The old Europe"
Offline Offline
Edison Member
Bootloaders suck!
View Profile
WWW
For completeness, see this post as well.
Logged
• Upload doesn't work? Do a loop-back test.
• There's absolutely NO excuse for not having an ISP!
• Your AVR needs a brain surgery? Use the online FUSE calculator.
My projects: RGB LED matrix, RGB LED ring, various ATtiny gadgets...
• Microsoft is not the answer. It is the question, and the answer is NO!
Pages: [1]   Go Up
Jump to:
