Loading...
Pages: [1]   Go Down
Author Topic: DIP 204-4 4-line-mode  (Read 747 times)
Offline Offline
Newbie
View Profile
after SPI-Mode does not work, i tryed with 4bit and Liquidcrystal...and i get a text-output...first thank you for the lib smiley-wink
here the Data-Sheet of the display:
http://www.lcd-module.de/eng/pdf/doma/dip204-4e.pdf
the example shows:
"hello, world!" in the first line - OK
"!" in the second line - FALSE (copy of line 1 cols >12 in line 2)
<seconds> in the 3rd line
i changed the row-offsets in LiquidCrystal.cpp see thread - same result
note that only 12 cols are accessable
col 13 [!] and following is printed also on line 2
i looked also in hardware/arduino/cores/arduino/print.cpp for the print-function (but this only uses write in a loop), and its not overwritten in LiquidCrystal.cpp/h
the library only supports 2-line-mode...
i added
#define LCD_4LINE 0x09 to LiquidCrystal.h and the following to the begin-method in the cpp:
  if (lines == 4) {
    _displayfunction = LCD_4BITMODE | LCD_4LINE;
  } else //now the (if lines >1)
now the display changes contrast (white on black,maybe "inverting cursor"), but why?
i cant still not access the 4 lines.. (2= line 3, 1=no text,3=no text)
i assume that the behaviour is because this display uses a "extended function set" to set number of lines, but i dont get it working yet (LCD_4LINE sets reversebit=inverse display)
RE-bit is set by functionset (DB2=4)
regards Frank
« Last Edit: September 16, 2011, 05:35:56 am by _frank_ » Logged
Offline Offline
Newbie
View Profile
successful enabled 4-line-mode:
LiquidCrystal.h:
// flags for function set
#define LCD_8BITMODE 0x10
#define LCD_4BITMODE 0x00
#define LCD_REBIT 0x04
#define LCD_2LINE 0x08
#define LCD_1LINE 0x00
#define LCD_5x10DOTS 0x04
#define LCD_5x8DOTS 0x00
//extended function set
LiquidCrystal.cpp:
void LiquidCrystal::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
  if (lines == 4) {
    _displayfunction |= LCD_REBIT;
  } else
  // finally, set # lines, font size, etc.
  command(LCD_FUNCTIONSET | _displayfunction);
  if (lines==4)
    command(LCD_4LINE);
    command(LCD_FUNCTIONSET | _displayfunction & !LCD_REBIT );
copy of col>12 persists no more (maybe HD44780 mode only supports 12 cols)
the cols (>=12) are also accessable by setcursor
hoping this will be added to the liquidCrystal lib in further arduino-software-versions
attached my LiquidCrystal.h/cpp based on version 0022
changes are marked by "//FW" appended by a char (a=add,d=delete,c=changed) on every changed line
some special chars are not working yet ($ like x), i try to make a conversion table (maybe charset german <> us) and charset us<>display
to get the $ on my display i have to do the following:
Code:
 char s[]="hello,world  ";
  s[12]=0xA2;
  lcd.print(s);
some special chars (german display):
Code:
  lcd.setCursor(0,2);//3rd line, first col
  char s2[20];
  //€ not in charset
  s2[0]=0x5B;//Ä
  s2[1]=0x5C;//Ö
  s2[2]=0x5E;//Ü
  s2[3]=0x7B;//ä
  s2[4]=0x7C;//ö
  s2[5]=0x7E;//ü
  s2[6]=0xBE;//ß
  s2[7]=0xFD;//{
  s2[8]=0xFF;//}
  s2[9]=0xA2;//$
  s2[10]=0x8F;//µ
  s2[11]=0xA0;//@
  s2[12]=0xFA;//[
  s2[13]=0xFC;//]
  s2[14]=0x90;//single note
  s2[15]=0x91;//double note
  s2[16]=0xDE;//arrow up
  s2[17]=0xDF;//arrow right
  s2[18]=0xE0;//arrow down
  s2[19]=0xE1;//arrow left
  s2[20]=0;
  lcd.print(s2);
« Last Edit: September 16, 2011, 07:41:17 am by _frank_ » Logged
Western New York, USA
Offline Offline
Faraday Member
View Profile
Now that you have posted the solution could you provide us with a description of the problem?
Don
Logged
Offline Offline
Newbie
View Profile
the display handles not the 4-line-mode of the EA DIP204-4 (maybe other 4-line-displays).
maybe you have to add an "if" at the changed row_offsets (they may not work with other displays, i don't have another to test)
more details are in the first post...but don't use the code provided there
Logged
Offline Offline
Faraday Member
View Profile
Quote
What do you mean by the 4-line mode?  Are you referring to the the 4 lines of characters on the display or are you referring to the 4 data lines connected to LCD pins 11, 12, 13, and 14?
Don
Logged
Offline Offline
Newbie
View Profile
4 lines of characters on the Display...
Logged
Offline Offline
Newbie
View Profile
cause my changes are not taken to arduino 1.0, i want to ask why
Logged
Pages: [1]   Go Up
Print
Jump to:
