Topic: DIP 204-4 4-line-mode (Read 2240 times) previous topic - next topic
_frank_
Sep 16, 2011, 11:49 am Last Edit: Sep 16, 2011, 12:35 pm by _frank_ Reason: 1
after SPI-Mode does not work, i tryed with 4bit and Liquidcrystal...and i get a text-output...first thank you for the lib ;)
here the Data-Sheet of the display:
http://www.lcd-module.de/eng/pdf/doma/dip204-4e.pdf
the example shows:
"hello, world!" in the first line - OK
"!" in the second line - FALSE (copy of line 1 cols >12 in line 2)
<seconds> in the 3rd line
i changed the row-offsets in LiquidCrystal.cpp see thread - same result
note that only 12 cols are accessable
col 13 [!] and following is printed also on line 2
i looked also in hardware/arduino/cores/arduino/print.cpp for the print-function (but this only uses write in a loop), and its not overwritten in LiquidCrystal.cpp/h
the library only supports 2-line-mode...
i added
#define LCD_4LINE 0x09 to LiquidCrystal.h and the following to the begin-method in the cpp:
 if (lines == 4) {
   _displayfunction = LCD_4BITMODE | LCD_4LINE;
 } else //now the (if lines >1)
now the display changes contrast (white on black,maybe "inverting cursor"), but why?
i cant still not access the 4 lines.. (2= line 3, 1=no text,3=no text)
i assume that the behaviour is because this display uses a "extended function set" to set number of lines, but i dont get it working yet (LCD_4LINE sets reversebit=inverse display)
RE-bit is set by functionset (DB2=4)
regards Frank
_frank_
#1
Sep 16, 2011, 12:59 pm Last Edit: Sep 16, 2011, 02:41 pm by _frank_ Reason: 1
successful enabled 4-line-mode:
LiquidCrystal.h:
// flags for function set
#define LCD_8BITMODE 0x10
#define LCD_4BITMODE 0x00
#define LCD_REBIT 0x04
#define LCD_2LINE 0x08
#define LCD_1LINE 0x00
#define LCD_5x10DOTS 0x04
#define LCD_5x8DOTS 0x00
//extended function set
LiquidCrystal.cpp:
void LiquidCrystal::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
 if (lines == 4) {
   _displayfunction |= LCD_REBIT;
 } else
 // finally, set # lines, font size, etc.
 command(LCD_FUNCTIONSET | _displayfunction);
 if (lines==4)
   command(LCD_4LINE);
   command(LCD_FUNCTIONSET | _displayfunction & !LCD_REBIT );
copy of col>12 persists no more (maybe HD44780 mode only supports 12 cols)
the cols (>=12) are also accessable by setcursor
hoping this will be added to the liquidCrystal lib in further arduino-software-versions
attached my LiquidCrystal.h/cpp based on version 0022
changes are marked by "//FW" appended by a char (a=add,d=delete,c=changed) on every changed line
some special chars are not working yet ($ like x), i try to make a conversion table (maybe charset german <> us) and charset us<>display
to get the $ on my display i have to do the following:
 char s[]="hello,world  ";
 s[12]=0xA2;
 lcd.print(s);
some special chars (german display):
  lcd.setCursor(0,2);//3rd line, first col
  char s2[20];
  //€ not in charset
  s2[0]=0x5B;//Ä
  s2[1]=0x5C;//Ö
  s2[2]=0x5E;//Ü
  s2[3]=0x7B;//ä
  s2[4]=0x7C;//ö
  s2[5]=0x7E;//ü
  s2[6]=0xBE;//ß
  s2[7]=0xFD;//{
  s2[8]=0xFF;//}
  s2[9]=0xA2;//$
  s2[10]=0x8F;//µ
  s2[11]=0xA0;//@
  s2[12]=0xFA;//[
  s2[13]=0xFC;//]
  s2[14]=0x90;//single note
  s2[15]=0x91;//double note
  s2[16]=0xDE;//arrow up
  s2[17]=0xDF;//arrow right
  s2[18]=0xE0;//arrow down
  s2[19]=0xE1;//arrow left
  s2[20]=0;
  lcd.print(s2);
floresta
Now that you have posted the solution could you provide us with a description of the problem?
Don
_frank_
the display handles not the 4-line-mode of the EA DIP204-4 (maybe other 4-line-displays).
maybe you have to add an "if" at the changed row_offsets (they may not work with other displays, i don't have another to test)
more details are in the first post...but don't use the code provided there
floresta
What do you mean by the 4-line mode?  Are you referring to the the 4 lines of characters on the display or are you referring to the 4 data lines connected to LCD pins 11, 12, 13, and 14?
Don
_frank_
4 lines of characters on the Display...
_frank_
cause my changes are not taken to arduino 1.0, i want to ask why
