Loading...
Pages: [1]   Go Down
Author Topic: trying to have multiple delays?  (Read 155 times)
Offline Offline
Newbie
View Profile
as of right now i have my arduino uno programmed to make the the servo move every 3 min. what i want to do though is after the servo has moved 12 times, i want it to stop for 10 hours and then start up again and does this in an endless loop till the power is unpluged
Code:
#include <Servo.h> //include the servo libary
Servo myservo;  // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0;    // variable to store the servo position
myservo.attach(9);  // attaches the servo on pin 9 to the servo object
for(pos = 15; pos < 85; pos += 85)  // interverls
myservo.write(pos);              // tell servo to go to position in variable ‘pos’
delay(180000);                       // waits 3 minutes for the servo to reach the position
for(pos = 85; pos>=15; pos-=85)     // max rotation
delay(500);                       // waits .5 second for the servo to reach the position
« Last Edit: September 17, 2011, 06:33:39 am by bengrvr » Logged
Netherlands
Offline Offline
Tesla Member
In theory there is no difference between theory and practice, however in practice there are many...
View Profile
First move the movement code from your sketch to a separate function. I called it move().
Then the code in loop() becomes relative simple,
(not tested myself)
Code:
unsigned long tick = 0;
  for (inti=0; i< 12; i++) move();
  delay(10L * 60L * 60L * 1000L);  // 10 hours but add an L to make it a long !!
void move()
Logged
Rob Tillaart
Nederlandse sectie - http://arduino.cc/forum/index.php/board,77.0.html -
Offline Offline
Newbie
View Profile
theres a problem with the code the highlighted part
void move()
Logged
New Jersey
Offline Offline
Edison Member
View Profile
It's just a typo - he warned you it was not tested- should be int i
Logged
Pages: [1]   Go Up
Print
Jump to:
