Topic: how can I add a second function to the same switch? (Read 620 times) previous topic - next topic
martin_80x
Thanks for your help with the other sketch ''from the beginning'', I got it working now.
what I want to do with this one is add a second function to the same switch
so the UPPIN can change cases and if I hold it change brightness too, same with DNPIN.
In the sketch I added the
int brightness = 50;    // how bright the LED is, stores the brigthness value
and the
unsigned long startTime = 0;  // when did we begin pressing?
to use it with millis?
and the cases are set to brightness instead
analogWrite(REDPIN, brightness);   // set to brightness
so this is the sketch
#define REDPIN 3
#define GREENPIN 5
#define BLUEPIN 6
#define UPPIN 4
#define DNPIN 2
int btnPressCount = 0;
int btnStateUp = LOW;
int lastBtnStateUp = LOW;
int btnStateDn = LOW;
int lastBtnStateDn = LOW;
  pinMode(UPPIN, INPUT);
  pinMode(DNPIN, INPUT);
btnStateUp = digitalRead(UPPIN);
if((btnStateUp == HIGH) && (lastBtnStateUp == LOW)) // Switch is pressed and was not
   btnPressCount++;       // Count this press
   lastBtnStateUp = btnStateUp;                     // Use btnPressCount
btnStateDn = digitalRead(DNPIN);
if((btnStateDn == HIGH) && (lastBtnStateDn == LOW)) // Switch is pressed and was not
   btnPressCount--;                                  // Count this press
   lastBtnStateDn = btnStateDn;                      // Use btnPressCount
     Serial.print("count = ");
     Serial.println(btnPressCount);
  //this part mantains the counts equal to 0
  // so it doesn't make the btnPressCount unsigned
  if(btnPressCount < 0)  // <-- Add me
      btnPressCount = 0; // <-- And me
   btnPressCount = btnPressCount % 3;               // Keep count in the range 0 to 6
  switch(btnPressCount)
   case 0:
  analogWrite(GREENPIN, 0);    // off
  analogWrite(BLUEPIN, 0);
     break;
    case 1:
  analogWrite(REDPIN, 0);
  analogWrite(GREENPIN, brightness);
  analogWrite(BLUEPIN, 0 );
     break;
    case 2:
  analogWrite(BLUEPIN, brightness);
     break;
PaulS
So, you want to time how long the switch is pressed. In order to do that, you need to know when the switch transitions from not pressed to pressed and when it transitions from pressed to not pressed.
Record when each transition occurs. When the transition from pressed to not pressed occurs, base your action on how long the switch was pressed. Short press == one action. Long press == other action.
Add
unsigned long upPress, dnPress;
unsigned long upRelease, dnRelease;
Initialize these variables at the appropriate times.
In the (new) if block following the up switch release detection, determine how long the switch was pressed. Increment either the button press count variable or the mode, depending on how long the switch was pressed.
martin_80x
#2
Sep 21, 2011, 01:49 am Last Edit: Sep 21, 2011, 02:27 am by martin_80x Reason: 1
question, do I have to start from scratch or keep working on this one?. Do I need to use millis?
I'm confused cause I'm looking at this example on how to fade but I guess is not even close on what you said
//checkwhether the button is being held down
if((digitalRead(UPPIN) == HIGH) && (digitalRead(DNPIN) == LOW))
   // if the button is held for more than 500ms.
   if (state == 1 && (millis() - startTime) > 500)
   brightness++;     //increment brightness by 1
Grumpy_Mike
Yes.
It is up to you if you start again.
BKnight760
You could attach an interrupt to your function.  That way the function gets called automatically when the button is pushed / let go.
http://arduino.cc/en/Reference/AttachInterrupt
Simply use millis() to record when the button state changes (is pushed / let go).  Subtract the two times.  Then do a specific action based on the elapsed time.  Reset the timers whenever the button is let go... after an action is done.
